Author Topic: Injector question?  (Read 2211 times)
September 03, 2009, 01:08:32 pm
BlastIt
  • 66
    • bigrblasting.com
Injector question?
« on: September 03, 2009, 01:08:32 pm »
I have an 82 rabbit pickup. Its a NA motor with a NA injection pump. I just installed a vnt-15 turbo. My question is do I
need to change the 130 injectors to 155 injectors? Will it hurt anything or effect performance to use the 130 injectors.
Thanks for any advice.
Reply #1September 03, 2009, 01:34:55 pm
Baron VonZeppelin
Re: Injector question?
« Reply #1 on: September 03, 2009, 01:34:55 pm »
Not your total answer, but getting the ball rolling.
91-92 EcoDiesel was turbo charged without LDA Fuel enrichment on the Inj Pump. So you are "somewhat similar" to that. Not saying identical.
It used the 155 bar injector pressure like the TD uses.
So you should probably be at 155 also.
Thats just using a theory, and as far as i can take it.
The other theory in my head is the bar pressure (130 vs 155) causes a slighter delay in the fuel charge. The engineers put them there on turbo applications for good reason is the only thing i'm sure of.
Probably upper rpms under boost is where it becomes more significant to have 155 bar.
Reply #2September 03, 2009, 02:38:23 pm
« Reply #2 on: September 03, 2009, 02:38:23 pm »
i ran a n/a 1.5 with a VNT17 for a couple years. i never had a problem with it. always ran like a top and had plenty enough fuel to blast 30+ psi out of that turbo. had stock n/a pump and 130 bar injectors. i dont think the engine really cares what injectors it has in it. only reason i swapped to 155's was cause i got a newer set with my turbo IP.
Reply #3September 03, 2009, 03:58:26 pm
BlastIt
  • 66
    • bigrblasting.com
« Reply #3 on: September 03, 2009, 03:58:26 pm »
Can you tell a difference between the 2?
Reply #4September 03, 2009, 05:41:19 pm
« Reply #4 on: September 03, 2009, 05:41:19 pm »
i cant for sure say there was such a difference in the injector, as there was in the fuel pump. i swapped injectors and pumps on the same day. but holy hell, it made my car come alive, and smoke alot.
Reply #5September 03, 2009, 06:13:31 pm
BlastIt
  • 66
    • bigrblasting.com
« Reply #5 on: September 03, 2009, 06:13:31 pm »
Is it a giles pump or a td pump?
Reply #6September 03, 2009, 08:09:30 pm
« Reply #6 on: September 03, 2009, 08:09:30 pm »
lol, a giles pump, are you kidding me? i dont have a steady source of income...
it was just a worn out td pump that i massaged a little.
