Non VW Group Diesel
idle RPM speed setting
Topic: idle RPM speed setting (Read 10886 times)
September 26, 2005, 10:04:26 pm
prysm
User+
September 26, 2005, 10:04:26 pm »
Is there any specific rule to set idle RPM?
I am asking this because my oil light started flickering after it has warmed up during idle.
I am hoping that it is just the oil sender or the idle RPM setting, because the next option would be to overhaul :cry:
I will try to install a oil pressure guage to verify if the oil pressure during idle. Other than I dont have any other option.
,prysm
mazda B2200 2.2L R2 diesel
September 27, 2005, 02:36:27 am
vwmike
Authorized Vendor
September 27, 2005, 02:36:27 am »
What kind of oil filter are you using?
September 27, 2005, 02:57:55 am
prysm
User+
September 27, 2005, 02:57:55 am »
what do you mean?
I'm using a vic C-407 for the primary and C-506 for the bypass. It's the same type that was orginally installed.
,prysm
September 27, 2005, 11:39:09 am
vwmike
Authorized Vendor
September 27, 2005, 11:39:09 am »
I just meant that sometimes a bad oil filter can cause oil pressure problems but if you're using OE filters then that shouldn't be a problem.
September 27, 2005, 01:06:12 pm
RedRotors
September 27, 2005, 01:06:12 pm »
Is it a VW car?
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
www.mikrotuning.com
www.hflox.com
September 27, 2005, 01:49:31 pm
zyewdall
September 27, 2005, 01:49:31 pm »
I put mine at about 700rpm. I figured to set it as low as it would idle smoothly, to reduce fuel usage at idle. The oil pump is a positive displacement pump, right? So the flowrate should be porportional to the rpm, and it will still get oil whenever the engine is turning, just less, and therefore less back pressure on the pump. And since there is very little stress on the engine at idle, compared to driving, a lower flow rate should be okay, in my thinking. If you run synthetic oil, or if the engine is really hot, it will also be thinner and reduce pressure. Anyone else have thoughts on this?
I also have a vernier throttle, which allows me to reset the idle higher if I need to (to warm up I usually set it to 1000rpm or a little higher)
'84 Mitsubishi 4x4 2.3L turbo biodiesel pickup
'91 VW Rabbit GTI with 1.6 biodiesel transplant
'81 Toyota longbed 2wd 2.2NA biodiesel pickup (for sale)
'89 Subaru 4x4 touring wagon
'82 subaru 4x4 TDI wagon -- project on hold
1976 Ford Sasquatch pickup
September 28, 2005, 12:40:46 am
prysm
User+
September 28, 2005, 12:40:46 am »
Quote from: "RedRotors"
Is it a VW car?
Marc/
nope it's a mazda b2200 R2 engine 2.2L
September 28, 2005, 07:25:09 am
fspGTD
September 28, 2005, 07:25:09 am »
I knew you had that engine :wink: , but you might want to put your vehicle/engine info in your signature in your profile to avoid future potential confusion.
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
September 28, 2005, 08:21:03 pm
prysm
User+
September 28, 2005, 08:21:03 pm »
:wink: fspGTD ok
I was able to connect a mechanical oil pressure guage last night. when I started the engine the pressure slowly went up to 35psi at cold idle, why? it's suppose to go up almost immediately. I am thinking maybe it's clogged or the oil pump is bad anyone has an idea?
If the any of the bearings are bad then shouldn't it go immidiately to a certain lower psi instead of going "slowly" to 35psi?
,prysm
March 29, 2012, 11:13:22 am
Re: idle RPM speed setting
March 29, 2012, 11:13:22 am »
thanks for bumping a
7 year old thread
lol...
March 29, 2012, 03:49:13 pm
March 29, 2012, 03:49:13 pm »
my rule of thumb;
turn it down till the change in the dash cubby is hopping up and down, then turn it up a tick.
Reply #11
March 30, 2012, 12:11:53 am
billybobf
89 golf 1.8 digi, 1.6 na in pieces in the shop
Reply #11 on:
March 30, 2012, 12:11:53 am »
they brought up a 7 yr old post to SPAM the site, notice his sig, and that its the ONLY post made?
Reply #12
March 30, 2012, 07:12:14 am
Moderator
Reply #12 on:
March 30, 2012, 07:12:14 am »
Apparent spam post by
jorgealarcon
deleted.
http://www.tunezilla.com
93 Eurovan AHU TDI
97 Golf Variant Syncro 1.9L 1Z TDI -
sold and missed
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Non VW Group Diesel
