what temperature thermostat for 1.6 diesel?
Topic: what temperature thermostat for 1.6 diesel? (Read 2437 times)
August 31, 2009, 06:16:13 pm
ilikevwdiesel
August 31, 2009, 06:16:13 pm »
80 or 87 degrees? opinions with reasons please.
My Bio
August 31, 2009, 06:33:27 pm
maxfax
Re: what temperature thermostat for 1.6 diesel?
August 31, 2009, 06:33:27 pm »
Considering your location, if you're using this car in winter you may want to opt for the warmer one, better heat and efficiency.. If it's a summer driver only, or if you were way down south the cooler stat would probably be fine...
September 01, 2009, 01:13:50 pm
92EcoDiesel Jetta
September 01, 2009, 01:13:50 pm »
I am running a 90C (195F) T stat in the 92 Ecodiesel. On the hottest days this summer (95F or so), the temp gauge stays in the same spot which is a bit above the middle. Before I put the 90C stat in, the temp gauge was midway between the 3/4 and max mark due to a T stat that wouldn't open.
