Author Topic: I got MAD soot. No good.  (Read 3870 times)
August 31, 2009, 10:27:02 am
therast
  • 3
« on: August 31, 2009, 10:27:02 am »
I have had 17 VW diesels.  I have had engines all apart have been in Injection pumps have and injectors, i adjust my own valves etc.  I am not saying this to look like a hero just to equate you with my mechanical aptitude.  This problem stumps me.  I have 2 vw diesels both NA.  One is an 85 mechanical lifter and the other is a 91.  I have had the 91 about 4 years and after owning it for about 18 months I noticed that I started getting a significant soot buildup on the trunk.  The car burned ZERO oil.  I had put a rabbit style fuel filter on it but have done that on many of my diesels with no issues.  I loved the big bumper body so I decided to trensplant the great running m85 mech motor into my 91 body.  The 85 motor didn't burn oil, had great acceleration and no soot.  So i made the transplant and now the 85 motor produces soot and the 91 motor in the 85 body does not.  The 91 body has always needed about 2 seconds of cranking to start unless it is the first start with glowplugs.  I was frustrated as heck at Christmas so I ripped off the water separator under the car and plumbed the lines together.  I am lost as heck.  Swapping motors in 90 degree weather was not a bunch of fun and i still have the problem.  Thanx for any help.
Reply #1August 31, 2009, 12:01:46 pm
smutts
  • 720
    ClackClackClackClackClack
Re: I got MAD soot. No good.
« Reply #1 on: August 31, 2009, 12:01:46 pm »
Fuel line weirdness? Tank venting weirdness? 1cwt of soot still sitting in the exhaust, collapsing air intake pipework, something that is still with the car? Happy Puzzling. :P
« Last Edit: August 31, 2009, 12:04:18 pm by smutts »
Reply #2September 02, 2009, 06:26:44 pm
Rabbit TD
  • 840
« Reply #2 on: September 02, 2009, 06:26:44 pm »
It's obviousy fuel feed related, why not get a lift pump and see if it helps.  Advance and Autozone has them for 45-60 dollars, the $60
one by Mr. Gasket is Diesel rated and has a pressure rating of 4-7 lbs.  They help eliminate those damn air bubbles too.
Reply #3September 02, 2009, 11:33:50 pm
therast
  • 3
« Reply #3 on: September 02, 2009, 11:33:50 pm »
I talked to a local truck diesel guy and he said check the return hose for blockage and I checked it against an 85 diesel I have and the 2 are pretty close.  Any suggestions on how to check the fuel lines?  I have looked and there is no visible leakage.
