Author Topic: starter not engaging?  (Read 1964 times)
August 31, 2009, 08:05:33 am
54321chris
« on: August 31, 2009, 08:05:33 am »
I just put an 02a tranny on my GTD, and when I turned the starter, it sounded like it was just spinning without engaging the flywheel.  I used the clutch and starter from the 02a (off an ABA from a mk3 golf).  Do I need some kind of spacer behind the clutch to bring it forward on this motor?
Reply #1August 31, 2009, 11:06:29 am
54321chris
Re: starter not engaging?
« Reply #1 on: August 31, 2009, 11:06:29 am »
Nevermind.  It's just the shaft not kicking out to engage the flywheel.
Reply #2August 31, 2009, 11:58:49 am
DCC
  • 184
« Reply #2 on: August 31, 2009, 11:58:49 am »
Tap it with a plastic hummer while someone turns the ignition key.. Sometimes works
