Author Topic: Which Nozzles in 1.9TD AAZ?  (Read 3250 times)
August 31, 2009, 04:01:43 am
Torchd
  • 372
« on: August 31, 2009, 04:01:43 am »
Hey guys!
I was considering changing the nozzles in my car. Its a mkIII golf 1.9td AAZ 1995, would any one know which nozzles this engine came with?
I am confused between SD308 and SD 297... Which engines came with these two nozzles?
Any help is appreciated!
Reply #1August 31, 2009, 07:51:41 am
Re: Which Nozzles in 1.9TD AAZ?
« Reply #1 on: August 31, 2009, 07:51:41 am »
im pretty sure the 308 didnt come in an AAZ. they are high flow preformance nozzles. ive been told they will work very well in my 2.0 5 cyl.
Reply #2August 31, 2009, 12:10:38 pm
Torchd
  • 372
« Reply #2 on: August 31, 2009, 12:10:38 pm »
Thanks.
Would you know which ones would the AAZ have?
And which motor has 308 and 297?
Cheers.
Reply #3August 31, 2009, 08:03:42 pm
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
« Reply #3 on: August 31, 2009, 08:03:42 pm »
DNOSD 308 IS FITTED TO THE AAZ TWO SPRING INJECTORS
DNOSD 297 IS FITTED TO THE SINGLE SPRING AAZ INJECTORS
HOPE THIS HELPS
GILES
Reply #4September 01, 2009, 12:08:36 am
Torchd
  • 372
« Reply #4 on: September 01, 2009, 12:08:36 am »
Thanks Giles for the reply!
So my car has came with SD308 then.
Would it matter if I install SD297 alongwith single spring injector bodies?
Reply #5September 01, 2009, 09:40:35 am
« Reply #5 on: September 01, 2009, 09:40:35 am »
well, since the SD297 came in single spring bodies, then yea, i would say you would be fine using single spring bodies for your 297 nozzles.
