TDI Engine -General Info
anything to look for? -Update motor after bad belt.
Topic: anything to look for? -Update motor after bad belt. (Read 3768 times)
August 28, 2009, 05:28:01 am
mr.woods
August 28, 2009, 05:28:01 am »
I might look at a '98 jetta TDI 5 speed tomorrow.
Is there anythig I need to look out for? It has 153,000 miles on it.
Last Edit: August 30, 2009, 01:44:37 pm by mr.woods
1.9 AAZ backed by a toyota tranny and dual cases, going into a rock crawler
August 28, 2009, 07:36:45 am
mr.woods
Re: anything to look for?
August 28, 2009, 07:36:45 am »
Never mind. Some people know how to post ads but not how to pull them.
August 28, 2009, 05:07:03 pm
August 28, 2009, 05:07:03 pm »
Too bad. As far as i'm concerned that year/ model was the one of the best cars VW ever built, esp. without power windows and sunroof. Any car that cost me less than $2000 , could do 150 KPH quietly while getting 53 mpg is awesome.
August 30, 2009, 04:32:44 am
smutts
ClackClackClackClackClack
August 30, 2009, 04:32:44 am »
53 mpg
Is that gallon US or IMP?
August 30, 2009, 01:07:33 pm
August 30, 2009, 01:07:33 pm »
Imperial, i am in Canada
August 30, 2009, 01:43:25 pm
mr.woods
August 30, 2009, 01:43:25 pm »
Ok update. I found a 2004 jetta with 214,000 miles. But the timing belt went on it, just shows a pic of the head off. My question is this, when the belt goes does it mainly just take out the valves and head, or can I expect to do the bottom end also? I know with the gassers I've messed with, every time a valve gets taken out, the rod bearings come soon after.
August 30, 2009, 06:38:05 pm
sawedoffgolf
Re: anything to look for? -Update motor after bad belt.
August 30, 2009, 06:38:05 pm »
ive seen that happen on a few friends hondas that a rod bearing usually fail and the rods were slightly bent . or you can get lucky like me and have the piston smashed into a million pieces.
November 02, 2009, 08:40:27 pm
macka
November 02, 2009, 08:40:27 pm »
If you are going to buy an engine with upper end damage, you are better off also doing the bottom end. That way you aren't getting the old stinky eye surprise. In my experience, when the engine goes for a crap in the top end, the bottom end more often then not sustains damage.
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
