1.9tdi with Gtd pump and turbo
Topic: 1.9tdi with Gtd pump and turbo (Read 2390 times)
August 28, 2009, 03:24:34 am
poole456
Newbie
August 28, 2009, 03:24:34 am »
Hi, have tried searching but found nothing.
I've sourced a gtd engine with good turbo and injector pump. Engine itself is seized.
I have a 1.9tdi engine already out of a mk3 golf, but want to get rid of the electronics.
Will the 1.9tdi run with the gtd pump bolted on? And also would the gtd turbo increase performance in comparison to the small turbo that's on the 1.9tdi at the moment.
August 28, 2009, 03:40:50 am
gigaz2
Re: 1.9tdi with Gtd pump and turbo
August 28, 2009, 03:40:50 am »
it will run, but thats about it
no power, no fun
August 29, 2009, 12:58:00 pm
August 29, 2009, 12:58:00 pm »
the IDI pump doesnt work on a TDI.
August 29, 2009, 01:18:07 pm
August 29, 2009, 01:18:07 pm »
It will run, if you can get it started. But it will have less power then a 1.6na
August 30, 2009, 04:25:12 am
smutts
ClackClackClackClackClack
August 30, 2009, 04:25:12 am »
If that isn't enough, I think the pumps have different offsets as well.
August 30, 2009, 05:24:24 am
jabcok20
Newbie
1.7 m-tdi vnt20 electronic map sensor
August 30, 2009, 05:24:24 am »
i drive a golf 1.9tdi 1z with turbo from 1.9td and that car have some power but no too much like good 1.9tdi with vnt. vnt make faster and higher pressure. for easy drive you can take that turbo but for bigger power no
