Author Topic: Vac pump  (Read 4748 times)
August 27, 2009, 06:23:18 am
T-ruck
  • 5
Vac pump
« on: August 27, 2009, 06:23:18 am »
I need a good vac pump for a 82 1.6. OR info on vain type to replace with. :'(
Reply #1August 27, 2009, 08:42:05 am
sour diesel
  • 19
Re: Vac pump
« Reply #1 on: August 27, 2009, 08:42:05 am »
I have one with rebuild kit lmk
Reply #2August 29, 2009, 02:24:09 am
sawedoffgolf
  • 213
Re: Vac pump
« Reply #2 on: August 29, 2009, 02:24:09 am »
i have a good vac pump that was rebuilt in the winter.
Reply #3August 29, 2009, 06:06:52 am
Re: Vac pump
« Reply #3 on: August 29, 2009, 06:06:52 am »
I have a couple of the mk2 style ones that basicaly never need to be rebuilt
Reply #4August 30, 2009, 11:29:52 am
T-ruck
  • 5
Re: Vac pump
« Reply #4 on: August 30, 2009, 11:29:52 am »
I'm still looking for a vac pump , But in my original post i did not say that i need a diaphragm type that has a good drive slot for the oil pump. the slot is inside the bottom of the gear on the vac pump. I've put a new oil pump in and really hate to put it into the slot that is worn as bad as mine is. SO if at all possible it would be nice to get a pic of the slot in the gear  PLEASE :)
Reply #5August 31, 2009, 09:49:13 am
Re: Vac pump
« Reply #5 on: August 31, 2009, 09:49:13 am »
im in oregon and i have a ton of diaphragm pumps. for both lengths of shafts. the 1.5 shaft and 1.6 shaft are different lengths. they are interchangeable, but you have to have the right oil pump for the right vac pump. pm me if you want, we can work something out and you probably wont have to pay shippin :)
