Author Topic: croma 0460 414 059 is this good for mtdi  (Read 2509 times)
August 27, 2009, 04:44:09 am
jabcok20
  • 15
    1.7 m-tdi vnt20 electronic map sensor
« on: August 27, 2009, 04:44:09 am »
hello i have pump from croma 0 460 414 059 but i catalogue it is croma 90-92. do you think this pump i good for 1.6td( i mean parts from it)
and in future for mtdi???????? someone told me that best pump is from croma 88-90
to put it to 1.6td i think i must take camplate and head with all plungers????? rest i will hold to mtdi
« Last Edit: August 27, 2009, 04:48:51 am by jabcok20 »
Reply #1August 27, 2009, 06:07:23 am
gigaz2
  • 626
Re: croma 0460 414 059 is this good for mtdi
« Reply #1 on: August 27, 2009, 06:07:23 am »
no, you should send it to me  ;D (really, send me a pm if you want to sell it)
it has a 11mm plunger, way too overkill for a 1.6td, users got 200HP with 9mm, no need for more on a TD
my advice: don't open it, save it for a mtdi as its one of few that is plug and play.
the older one you refer is way better as the new one is limited because of emmisions
Reply #2August 27, 2009, 11:57:55 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #2 on: August 27, 2009, 11:57:55 am »
  ;D
That is a cool bit of information! Thanking you for the inspiration of a new project. 8)
Reply #3August 27, 2009, 12:38:47 pm
snakemaster
  • 405
« Reply #3 on: August 27, 2009, 12:38:47 pm »
  ;D
i would say it will run ok , but could not see it pulling more than 110hp , but it could be moded , be a good start off for a Mtdi
dose any one no if the pullys run in line with this pump ?
