General Information
General
GVWR - accomplished
Topic: GVWR - accomplished (Read 5280 times)
August 26, 2009, 06:38:59 pm
Luckypabst
GVWR - accomplished
August 26, 2009, 06:38:59 pm »
Right at the GVWR with an ironworker, a dog and myself...
5th gear just laughed at me (or was it crying?). I have to go 250 miles like this on Friday, into the greater LA area.
Chris
'82 TD Westy
'81 NA Caddy
August 26, 2009, 08:21:21 pm
Re: GVWR - accomplished
August 26, 2009, 08:21:21 pm »
Nice truck.
What is that exactly?
August 26, 2009, 08:28:14 pm
Luckypabst
August 26, 2009, 08:28:14 pm »
It's a little 30 ton ironworker
'82 TD Westy
'81 NA Caddy
August 27, 2009, 12:46:23 am
Turbinepowered
August 27, 2009, 12:46:23 am »
Quote from: Luckypabst on August 26, 2009, 08:28:14 pm
What's it do? I'm assuming "30 ton" refers to an applied pressure rating of some sort? Not it's actual weight?
August 27, 2009, 07:03:53 am
Luckypabst
August 27, 2009, 07:03:53 am »
Yea, that's a potential force of 30 tons... The truck would be flat if it weighed that much!
It has a punch and shear station and a place for interchangeable tooling - I have the plate bender and angle iron shear for it.
Chris
'82 TD Westy
'81 NA Caddy
August 31, 2009, 08:24:57 am
August 31, 2009, 08:24:57 am »
i would have put it right over the rear axle. ive seen a rabbit truck bent before from overloading it too far forward. it only had 27k miles on it, was a diesel, had a 5 speed, still the original owner too.
August 31, 2009, 04:46:21 pm
Luckypabst
August 31, 2009, 04:46:21 pm »
That's where we put it first and where I would have rather left it. I certainly had too much weight over the front axle (only rated to 177? additional lbs). The rear axle is rated to something like another 940 lbs but the springs didn't like all that weight... maybe 30 years ago it would have worked.
Chris
'82 TD Westy
'81 NA Caddy
General Information
General
GVWR - accomplished
