Author Topic: Power steering pump for water I.C. cooler pump  (Read 4699 times)
August 25, 2009, 01:04:10 pm
GEE-BEE
  • 1604
« on: August 25, 2009, 01:04:10 pm »
Has anyone used the stock AAZ power steering pump for a water I.C.pump for there water cooled intercooler ?
I look at the fittings on the pump and I think this will work ?
what kinda of psi does the pump create ?
Cheers !
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1August 25, 2009, 02:40:21 pm
smutts
  • 720
    ClackClackClackClackClack
Re: Power steering pump for water I.C. cooler pump
« Reply #1 on: August 25, 2009, 02:40:21 pm »
It might! just work with water and that soluble oil used for cooling machine tools and lathes, but there might be a reason why nobody else has done this. ;)
Reply #2August 25, 2009, 02:46:28 pm
GEE-BEE
  • 1604
« Reply #2 on: August 25, 2009, 02:46:28 pm »
I was thinking of synthetic water ( Water Wetter )????
Giles Pump OHC
MK1 JETTA DASH
Reply #3August 25, 2009, 06:05:12 pm
« Reply #3 on: August 25, 2009, 06:05:12 pm »
i think it would be easier to just run an eletric water pump, they can't be expensive
Reply #4August 25, 2009, 06:54:00 pm
53 willys
« Reply #4 on: August 25, 2009, 06:54:00 pm »
long as you ran some sort of water lube for the rust you will be fine(they sell it at napa).....will a PS pump actually move water?? or is water too thin?
Reply #5August 25, 2009, 07:52:15 pm
rabbid79
  • 684
« Reply #5 on: August 25, 2009, 07:52:15 pm »
Why not just run PS fluid?  Could the PS fluid carry enough heat away?  And yes, electric water pumps can be found cheap.  I watched a new genuine Audi one on eBay sell for $10 last week.  You can also spend a lot of more on one.  PWR sells a Bosch one for $179.
'15 WRX
Reply #6August 25, 2009, 08:34:43 pm
« Reply #6 on: August 25, 2009, 08:34:43 pm »
I love the idea and the thinking outside of the box. I would do it if I were you and tell us how it goes. My only concern is how much HP will it rob to drive it? When dirt track racing we usually got rid of the PS pump and the alt and it helped the throttle response quite a bit. How much difference between the electric pump draw and the PS pump only you could tell us:D.
Reply #7August 25, 2009, 10:33:49 pm
sawedoffgolf
  • 213
« Reply #7 on: August 25, 2009, 10:33:49 pm »
if hes already got the P/S pump, then why not? if it works then awesome, if not then switch to a electric pump. the porsche ones work wicked, my friend is using one on a tdi.
Reply #8August 25, 2009, 10:46:59 pm
  • 3468
    • McScrubbins Body Wash
« Reply #8 on: August 25, 2009, 10:46:59 pm »
i was under the impression that pwr steering pumps pumped at very  very high pressure...
Reply #9August 26, 2009, 12:24:59 am
GEE-BEE
  • 1604
« Reply #9 on: August 26, 2009, 12:24:59 am »
That's what I was thinking...
Just a Idea out of the box..  ;)
Giles Pump OHC
MK1 JETTA DASH
Reply #10August 26, 2009, 08:39:43 am
« Reply #10 on: August 26, 2009, 08:39:43 am »
why not use a VR6 aux coolant pump? you can get them all day used for 20 bux or less.
Reply #11August 26, 2009, 10:05:45 am
GEE-BEE
  • 1604
« Reply #11 on: August 26, 2009, 10:05:45 am »
I will do bosch ( new ) , pull the ps pump off
Doing a PD150 WITH A WATER COOLED I.C.
Iam going to have manifold drilled and tapped for the mcnally guage , then to extrudeahone for polishing , then off to powder coating
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #12August 26, 2009, 11:45:46 am
53 willys
« Reply #12 on: August 26, 2009, 11:45:46 am »
if it was me I would try something like this..
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9576
Reply #13August 26, 2009, 12:24:19 pm
« Reply #13 on: August 26, 2009, 12:24:19 pm »
basically a knock off shur-flo wash down pump. see them on alot of boats. dont move much volume. but the impellers last forever. not high pressure or high volume. i would use a centrifugal pump, like whats found on VR6's and newer vw's. maybe not that exact pump, but something like it.  centrifugal pumps dont have very high pressure, but they move alot of volume.
Reply #14August 26, 2009, 01:19:39 pm
53 willys
« Reply #14 on: August 26, 2009, 01:19:39 pm »
240gph is pretty good volume I would say?? you dont really need any pressure...just be able to move the fluid through a cooler...
