Author Topic: EGT sensor placement in a TDI [not mTDI]  (Read 7481 times)
August 19, 2009, 05:25:28 pm
  • 1739
« on: August 19, 2009, 05:25:28 pm »
I"m asking this for someone i know who spent a year or 2 doing a nice installation of  an ALH  TDI into a Pinzgauser. He's trying to get more performance out it- chip, bigger nozzles etc. I told him he should get an EGT gauge. He went ahead and installed ,putting the probe i believe where the EGR pipe used to come out. Going up big hills under throttle he's only seeing 800 o max. Is it possible the probe is too far downstream, or is it because the  ECU driven fuel management keeps the  exhaust temps  low ?
Reply #1August 21, 2009, 07:56:04 pm
macka
  • 957
Re: EGT sensor placement in a TDI [not mTDI]
« Reply #1 on: August 21, 2009, 07:56:04 pm »
Sounds like it could be too far down stream. He should get a laser thermometer and shoot a temp reading higher up stream and compare what the EGT says to what the thermometer says higher up stream.
Quote from: Vincent Walden
Reply #2August 28, 2009, 07:15:12 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #2 on: August 28, 2009, 07:15:12 am »
the EGR port is the wrong location for the EGT probe. Thats where I had mine but I knew it was wrong and the next time I pulled the turbo I planned on drilling a new port for it in the manifold itself.
Reply #3August 30, 2009, 06:41:37 pm
sawedoffgolf
  • 213
« Reply #3 on: August 30, 2009, 06:41:37 pm »
In my girlfriends car we had the egr delete. we taped the block off plate and got a longer probe, havent had any issues and it seems very accurate. i will try and find the link to the probe we are using.
Reply #4September 05, 2009, 12:39:58 am
sawedoffgolf
  • 213
« Reply #4 on: September 05, 2009, 12:39:58 am »
this is the same probe we have, but this kit also has the blockoff plate.
http://www.tdiparts.com/catalog/product_info.php?products_id=1202
