Author Topic: When was my TDI engine built?  (Read 4876 times)
August 17, 2009, 05:48:03 am
Iantheplumber
  • 1
« on: August 17, 2009, 05:48:03 am »
Hi,
I have a camper van that has had a Mk3 golf 1.9 TDI engine conversion. My problem is whenever I try to buy parts I get asked the vehicle reg for the engine, which I have no way of finding out. I'd like to find the age of the engine and if it is a 'AAZ' or other code. The engine number is 028103373N and I was told it came from a Mk3 golf. Can anyone help please?
Thanks
Ian
PS. its really quick for a camper van!
Reply #1August 17, 2009, 07:06:37 am
Re: When was my TDI engine built?
« Reply #1 on: August 17, 2009, 07:06:37 am »
Unfortunately the MK3 was a transition chassis for VW and they used several different types of engines, and it varied between North America and Europe as well.  My parts catalog doesn't find that particular block part number.
If you have a throttle cable it's an IDI engine, probably an AAZ.... if the throttle is fully electronic it's probably an early version of the TDI engine (perhaps an AHU).  There;s a description of IDI and TDI in the FAQ which may help as well.
Best bet is to post a couple pictures of the top of the engine and we'll be able to tell for sure.
Reply #2August 17, 2009, 11:40:09 am
MikkiJayne
  • 235
« Reply #2 on: August 17, 2009, 11:40:09 am »
That number you posted is not the engine number. Its probably just a casting number and there's not much we can glean from that  ;)
The engine number is stamped on to a flat just below the head and just above the oil cooler housing. It will be a two or three digit code and six numbers. As Vincent said if it's got a throttle cable it will be an AAZ. If it hasn't it will be a 1Z (93-95) or AHU (96-98). If you can find the code we can give you a year in the middle of the run so you stand a good chance of getting the right bits  :)
Reply #3August 18, 2009, 01:08:26 pm
snakemaster
  • 405
« Reply #3 on: August 18, 2009, 01:08:26 pm »
post a few pics that will help us , when i go to get parts thay say reg no  ::) and i say its a 1Z and then thay still not got a qlue , what parts you after some one may be able to put the part no up for you after we no what engine you have
Reply #4August 22, 2009, 09:33:36 am
gigaz2
  • 626
« Reply #4 on: August 22, 2009, 09:33:36 am »
problem is even that it is a 1Z, there were two main generations, I thing they change about 275000
the code is right below the head, over the oilfilter connections, usually under a lot of grime.
its like: 1Z 234900
