Author Topic: Monster Spec pump, searched but no info found!  (Read 4629 times)
August 15, 2009, 02:34:34 am
ryanp
  • 269
« on: August 15, 2009, 02:34:34 am »
I fancy building a monster spec 1Y with a pump to match. The 1Y is a 1.9D to which a turbo will be added, I'm thinking VNT but that's another topic! I've looked and looked but I can't seem to find the definitive topic which shows what a decent, low budget self built pump is. From my research I think the following would be good:
20mm shaft base pump (which?)
11mm/12mm Head and springs
1Y cam plate
Peugeot LDA setup??
Governor Mod
Advance mod
Are the foundations there? I don’t know what other internals would be best or even what else could be changed for the better.
I've got acess to almost any pump to make this work so i might as well make the most as i doubt i'll build another IDI after this one!
Thanks for any help!
Ryan
« Last Edit: September 08, 2009, 10:31:11 am by ryanp »
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #1August 15, 2009, 09:37:39 am
Re: Monster Spec pump, searched but no info found!
« Reply #1 on: August 15, 2009, 09:37:39 am »
talk to 53willys or Zukgod or giles or one of those guys that build there own 11mm hot pumps. dillenger1 built a pretty bad ass 10mm pump out of some peugeot pump parts. why dont you just use a 1.6 turbo pump, its already setup pretty close to what you want. put the 11mm pump in there, shim up the governor. why would you want to remove it? its not going to turn 7000 rpms. if you shim it a quarter inch, the governor works at about 20% what it should be working. it simply cant cut enough fuel with it shimmed up.
you should listen to the guys on here, they have lots and lots of good info. everyone on here says the 1.6 turbo pump has a good cam plate and seems lime most people stay away from stock 1.9 parts. whats so much better about a peugeot LDA from a vw unit? and are you going for used parts here? cause if you are going for new, i was going to order a volvo penta 11 or 12mm pump. they are capable of almost 300 bar too! and fairly cheap.
Reply #2August 16, 2009, 06:51:22 am
ryanp
  • 269
« Reply #2 on: August 16, 2009, 06:51:22 am »
Ahh, I did'nt know that about the govener, I'm still learning. I just saw a few posts saying to remove it and thought that was the way to go, Although 7000RPM sounds good!! I think i could still be pulling at 6k with the turbo and other work i'm planning!
The reason i posted this topic is to find out all the info i'd never find if i looked. I've seen people have used the peugeot LDA setup as there are loads of nice parts inside, what, I dont know! lol I do know that the PUG's have a higher RPM limit which might mean better internals (the guy in the link below mentions some mods to the 'top' of the pump)
I was trying to make up a good pump from the parts i can get cheap or free, if i'm better starting with a 1.6td pump I'll have to buy one!
This guy made me think some of the 1y stuff is OK:
http://www.vwdiesel.net/forum/index.php?topic=16008.0
If anyone else can chime in and give me some advice that would be great!
Ryan
« Last Edit: August 16, 2009, 06:54:27 am by ryanp »
Reply #3August 16, 2009, 11:04:33 am
« Reply #3 on: August 16, 2009, 11:04:33 am »
dude, these engines just dont really pull much past 5500 or so. i have good boost and fuel at 5500, but it just makes alot of noise really, i usually shift right about 5000, when it starts falling on its face. i used to be right where you were, thought making a super spinner diesel sounded awesome, but its just not feasible. diesel doesnt burn fast enough and our pumps cant pump it fast enough. you can take a 100% completely stock engine, port the head, put a good intake, a good exhaust, and a good turbo on there with an intercooler, you can make beautiful power. there is nothing special about my 1.5, and it will burn the tires off in 2nd gear for over 100 feet all posi'd up. first time i ever did that i was so impressed that i just couldnt let out, i had to give her all i had, and it finally caught traction at about 30 mph.
Reply #4August 16, 2009, 11:25:36 am
MJF
  • 581
« Reply #4 on: August 16, 2009, 11:25:36 am »
If your engine doesnīt work above 5000rpm, that doesnīt mean any engine will not work. My 1,7 revīd to 5800 and then power dropped. And there is engines that revīs higher than that. Even 7000, with regular pump diesel.
Do you have dyno sheet from your 1,5?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #5August 16, 2009, 12:06:16 pm
« Reply #5 on: August 16, 2009, 12:06:16 pm »
no, my engine will turn ALOT more than 5500 rpms. it still pulls after 5500, just not hard like it pulls before 5500. i bet my car damn near turns 7k. it turns soo many rpms, that the engine will get quieter.
and who can afford to get there car dyno'd anymore? not me. and besides, the dyno is 100 miles away. i cant drive! (legally)
Reply #6August 17, 2009, 01:08:23 am
Aki-76
« Reply #6 on: August 17, 2009, 01:08:23 am »
I build my daily car 1.9td orginal pump+11mm bosh head,modified governor,nothing super special only normal parts and itīs revs up to + 6000rpm raising power curve.That rpm needs very good sylinder head,exhaust,intake..
I think all diesel engines revs that much but only few do serioius power that high rpmīs
My daily vento power is about 190hp,only  :-[
Reply #7August 17, 2009, 01:44:43 am
ryanp
  • 269
« Reply #7 on: August 17, 2009, 01:44:43 am »
Are there any certain Bosch heads to choose over other ones? or will any do?
I'll be building the engine to suit!
Thanks
Ry
Reply #8August 17, 2009, 12:35:26 pm
« Reply #8 on: August 17, 2009, 12:35:26 pm »
a pump head is a pump head, its the delivery valves and injectors and *** that make them different.
Reply #9August 17, 2009, 07:15:27 pm
Rabbit TD
  • 840
« Reply #9 on: August 17, 2009, 07:15:27 pm »
I'm glad you mentioned something about delivery valves.  All you ever hear about is the cam plate lift, the injector breaking pressures and the size of the pump.  I've alwys wanted to know more about the delivery valves themselves and how they fit into the picture, obviouly they have to open before the injectors do but you never hear if or what should be done with them for increased power or how it affects mileage, heat and ect.
Reply #10August 18, 2009, 10:51:11 am
« Reply #10 on: August 18, 2009, 10:51:11 am »
Very little.
The DV is basically there to hold residual line pressure between the pump and injector.
In our applications using a larger DV isn't going to get much if anything as far as performance goes.
I've tried larger DV's when I used my 11mm head and didn't notice crap. No I didn't dyno it and wouldn't either knowing what it's purpose really is.
Cummins owners (myself included) have been using larger DV's for a while. Usually end up with crappy idle. In most cases that doesn't matter as it's a pulling truck and not a daily driver.
« Last Edit: August 18, 2009, 10:56:57 am by zukgod1 »
Reply #11August 25, 2009, 02:13:04 am
ryanp
  • 269
« Reply #11 on: August 25, 2009, 02:13:04 am »
Dan,
Do you have any input regarding the pump build? How much would you charge to put it all together if i sent you a few nice pumps to play with?
Cheers
Ry
Reply #12August 25, 2009, 09:32:18 am
« Reply #12 on: August 25, 2009, 09:32:18 am »
Ry,
Send me an e mail @ zukgod1 at comcast dot net and we can discuss your build..
Reply #13August 25, 2009, 11:45:21 am
ryanp
  • 269
« Reply #13 on: August 25, 2009, 11:45:21 am »
dropped you an email dude!
Ryan
Reply #14September 08, 2009, 10:24:03 am
ryanp
  • 269
« Reply #14 on: September 08, 2009, 10:24:03 am »
What pump is a good base for this pump? obviousy a 20mm shaft is required!
Any negatives to me building a 12mm Pump? I want the revs!
Cheers
Ryan
