Author Topic: bad brake pedal  (Read 3837 times)
September 21, 2005, 08:05:04 pm
SMOKEYDUB
  • 630
bad brake pedal
« on: September 21, 2005, 08:05:04 pm »
I bled all the air out of the system of my a2 jetta and installed 10.1 inch brake kit. Whats wrong? Do I need the master cylinder from the passat? Anyways I am more then likely just going to change it to the passat one To see if its the problem.
Thanks
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1February 25, 2006, 08:40:49 am
hillfolk'r
  • 1532
bad brake pedal
« Reply #1 on: February 25, 2006, 08:40:49 am »
maybe,,i ran into this snag on my 83 gti wheni put 10.1 kit on front,,,ihave more pedaltravel,,,doesnt really bother me though,cause of bigger caliper pistons,,,,need the 16v master also,and it would be right,,,i kinda like more pedal travel,,gives more "feel" at the limit,,,,
Throttle cables ftw
Reply #2March 13, 2006, 04:53:01 pm
moosiah
  • 106
mushy brake pedal
« Reply #2 on: March 13, 2006, 04:53:01 pm »
I got the same mushy pedal on my 81 rabbit w 10.1 frts w 200mm rears. It looks like I 'll hafta change to the 22 mm mastercyl ........ darn I just put on a new 21mm master.......... I thought that you only had to do that for rear discs .  :? Oh well ... I guess that means that I'll also have to change the vac canister to the 9" too........ more bug hunting in the yards....... :wink:
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
