Author Topic: 1.6 turbo diesel H-beam rods  (Read 8272 times)
Reply #15August 14, 2009, 04:18:00 pm
Re: 1.6 turbo diesel H-beam rods
« Reply #15 on: August 14, 2009, 04:18:00 pm »
they better come balanced.
Reply #16August 14, 2009, 04:19:50 pm
« Reply #16 on: August 14, 2009, 04:19:50 pm »
within 1 gram of each other. i would balance them more.
Reply #17August 23, 2009, 07:02:06 pm
Syncroincity
  • 727
« Reply #17 on: August 23, 2009, 07:02:06 pm »
$500 isn't bad for those, that's about what the 1.9 rods cost. Has anyone contacted them about shipping? Some companies are leery of shipping to the US (Brickwerks, for one) because of liability issues. ::)
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #18August 23, 2009, 07:11:30 pm
macka
  • 957
« Reply #18 on: August 23, 2009, 07:11:30 pm »
if you can get them within 25mg of each other they would be the cats ass for B&B engines. IIRC thats what the tractor pull guys use as the max, and they run cum aparts at 9k rpm on average per pull.
Quote from: Vincent Walden
Reply #19August 23, 2009, 11:47:07 pm
VWSmokr
  • 40
« Reply #19 on: August 23, 2009, 11:47:07 pm »
... It is my observation that peening, polishing, balancing and rod bold upgrade should be good enough for most of the motors built "round here.  ;)
How important is it to upgrade the rod bolts (ARP?) in a turbo rebuild if not planning to go over 15-20psi? My 1.6 assembly is all balanced no; will replacing the stock oem rod bolts with ARP's be likely to throw it off enough that it should be re-balanced?
J.R.
SoCal
J.R.
SoCal
Reply #20September 24, 2010, 03:42:19 am
Alcaid
  • 549
« Reply #20 on: September 24, 2010, 03:42:19 am »
Did anyone end up trying these rods?
'10 VW Passat 1.6TDI Highline
Reply #21September 29, 2010, 05:46:03 pm
bugnut
  • 89
« Reply #21 on: September 29, 2010, 05:46:03 pm »
I asked about these rods and I found the price diff. from the pauter and these to be $250 and they are made in china.  So I went for the pauter rods.  I ordered them 3 weeks ago.  Still have 4 weeks till they get here.  There were none in stock so I am getting them right off the press.  Will take pictures when they get here.
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #22September 29, 2010, 08:09:07 pm
rabbid79
  • 684
« Reply #22 on: September 29, 2010, 08:09:07 pm »
Pauter's should be awesome! :o  I look forward to the pics of these.  Money well spent right there.
'15 WRX
Reply #23September 30, 2010, 03:40:32 am
Alcaid
  • 549
« Reply #23 on: September 30, 2010, 03:40:32 am »
The Pauter rods are cross-beam/X-beam, aren't they? Wouldn't the H-beam design be superior in strength?
Reply #24September 30, 2010, 05:16:26 am
rabbid79
  • 684
« Reply #24 on: September 30, 2010, 05:16:26 am »
It's the same old discussion.  Maybe.  But I've never heard of a Pauter rod failure.  When you look at the construction of a Pauter X-beam rod, espcially where the main body of the rod meets big and pin ends, you'll realize just strong the rod is.
'15 WRX
Reply #25December 21, 2010, 11:26:14 pm
Alcaid
  • 549
« Reply #25 on: December 21, 2010, 11:26:14 pm »
Bumping this one, anyone tried these?
