Author Topic: mk2 or mk3 unsure which to use...  (Read 9801 times)
August 08, 2009, 08:33:07 am
bobmaf
  • 65
« on: August 08, 2009, 08:33:07 am »
i have a mk2 1.6 gtd and i have a mk3 1.9td (aaz engine)
which would better the mk2 with the aaz engine installed into it
or leave the mk3 and tweak that ????
1991 mk2 1.6GTD tuned
1995 mk3 1.9TD Part Tuned(aaz)
Reply #1August 08, 2009, 08:35:34 am
Re: mk2 or mk3 unsure which to use...
« Reply #1 on: August 08, 2009, 08:35:34 am »
They are both good engines but with pretty different characteristics. What are your goals for the car?
Reply #2August 08, 2009, 08:49:28 am
bobmaf
  • 65
« Reply #2 on: August 08, 2009, 08:49:28 am »
well either way they are better than petrol in costs/mpg so mpg isnt an issue
but yeh i`m after top end speed and set off speed
my mk2 1.6gtd tuned is quick but not quick enough
Reply #3August 08, 2009, 09:55:13 am
LoneWolf
« Reply #3 on: August 08, 2009, 09:55:13 am »
mk2 with the mk3 engine, but use the mk2 turbo setup, thats what im running, its pretty economical and a good bit of fun to drive :)
Reply #4August 08, 2009, 10:03:35 am
bobmaf
  • 65
« Reply #4 on: August 08, 2009, 10:03:35 am »
i spotted something about upgrading the injectors do u know anything about that ??
Reply #5August 08, 2009, 10:20:20 am
LoneWolf
« Reply #5 on: August 08, 2009, 10:20:20 am »
TBH im not too well clued up on injector swapping, but ive been lead to believe that for mild tuning the AAZ (mk3) injectors are good to go
Reply #6August 08, 2009, 10:47:22 am
bobmaf
  • 65
« Reply #6 on: August 08, 2009, 10:47:22 am »
well i collect my aaz mk3 next week so al see how she drives still in the mk3 body first and then see if she wants an older shell to ride in
cheers
Reply #7August 10, 2009, 06:56:23 am
« Reply #7 on: August 10, 2009, 06:56:23 am »
you will love the torque of the 1.9.  the only thing i would recommend is a taller transmission as the 1.9 doesn't like to rev like the 1.6.
Reply #8August 10, 2009, 07:46:00 am
bobmaf
  • 65
« Reply #8 on: August 10, 2009, 07:46:00 am »
which transmission would be best ?
Reply #9August 11, 2009, 03:26:10 pm
rallydiesel
  • 1880
« Reply #9 on: August 11, 2009, 03:26:10 pm »
Or put the 1.9 head on the GTD. If you go with the AAZ in the mk2, use the GTD pump and take the camplate out of the AAZ pump and put it in the 1.6 pump. The 1.6 pump has more adjustability than the AAZ pump. Don't bother messing with the nozzles, the GTD pump with the 1.9 camplate will put out more than enough fuel.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10August 12, 2009, 04:45:26 am
bobmaf
  • 65
« Reply #10 on: August 12, 2009, 04:45:26 am »
ok well i wont be doing anything just yet as i`m going to get the mk2 body all repaired and resprayed before i do any changes to the engine
cheers
Reply #11August 12, 2009, 10:54:38 am
LoneWolf
« Reply #11 on: August 12, 2009, 10:54:38 am »
You got any pics then Bob m'laddo?
Reply #12August 14, 2009, 06:08:31 am
bobmaf
  • 65
« Reply #12 on: August 14, 2009, 06:08:31 am »
i use a freinds tinterweb so i dont have any pics
ive got loads on my phone lol
well i got my mk3 (aaz) yesterday and she drives quite nice i`m suprised but i am still going to drop the aaz into my mk2 and shuv the gtd into my mk3 and use it for a while until i get everything sorted on the mk2  ... aaz requires a clutch desperatly and i aint sure if the 1.6 clutch will fit the 1.9
Reply #13August 14, 2009, 01:51:00 pm
  • 3468
    • McScrubbins Body Wash
« Reply #13 on: August 14, 2009, 01:51:00 pm »
1.9 head on the GTD gets my vote!!! :D
Reply #14August 22, 2009, 08:45:08 am
bobmaf
  • 65
« Reply #14 on: August 22, 2009, 08:45:08 am »
well ive changed the boost pin i swapped it with the one out of my gtd and it made a hell of a difference ive turned the fuel up, blocked the wastegate/dumpvalve thing and its lovely now
next job is to do the gov mod and install the intercooler....... wow its going to be lovely when i put the engine into my mk2
