Author Topic: Where's this electrical connector plug into the fusebox?  (Read 3908 times)
August 07, 2009, 06:37:55 am
Kneale Brownson
  • 120
« on: August 07, 2009, 06:37:55 am »
This Pix  is of a connector with a fairly heavy ( whatever metric lies between a 12 and 14 gauge) red wire and connector that plugs into the back of the fuse panel in a '95 Jetta TD.
The connector is the type that grips a projection on the INSIDE of the slot into which the connector goes.  Most of the other single wire connectors have a fixture that grips the outside of the slot.
Anyway, there is another smaller red wire with a similar connector I haven't replaced either.
Additionally, when I put the connector back into Slot J on this schematic:  http://www.xjamiex.com/mk2resource/electrical/CE2.html     it didn't go all the way in, and I noticed it was loose after I had the battery power hooked up to the fusebox already, so when I pushed the red connector back into place (and heard the retainer click properly this time), I also heard the lock system cycle.  Now the locks have stopped working together (turn key in door lock and only that door locks), and the trunk lock won't release.  Is that all associated with the red wire in the picture?
Reply #1August 07, 2009, 02:51:36 pm
Re: Where's this electrical connector plug into the fusebox?
« Reply #1 on: August 07, 2009, 02:51:36 pm »
Did you swap out fuse boxes or something? There are a lot of wires back there and a lot of them don't do anything. I know on my car there are at least 5 wires that aren't hooked up to anything.
Reply #2August 07, 2009, 07:04:54 pm
Kneale Brownson
  • 120
« Reply #2 on: August 07, 2009, 07:04:54 pm »
I started removing the wires so I could remove the fusebox and examine it for evidence of shorts/other issues, and realized when I had it about half undressed that I'd never get all the wires back into the right places.  Turned out I was right.
I know there are connectors/wires there that weren't used previously.
But I'm pretty sure this one was plugged into the back somewhere near the passenger end of the fuse panel.  I've looked and looked with a light and mirror, but I can't identify a slot where there are internal keepers for the connector.
