Author Topic: MORE !All kinds of diesel parts for sale  (Read 8211 times)
August 01, 2009, 09:24:15 am
  • 1739
« on: August 01, 2009, 09:24:15 am »
Sorry about some of the poor pics,I will try to describe what there is. All prices +shipping and handling. I will negotiate.
Silver faced cluster Mk3 .Gasser tach doesn't work. Can be made to fit your diesel cluster $35
1.6 D alternator Tested recently $25
1.6 D starter Tested recently $25
1.9 AAZ mk3 alternator 70 amp.Tested recently $35
ALH valve cover, coolant flange ,vacuum pump $10 each
ALH oil pan and cracked but decent plastic cover $50.
2[only !] TDI pistons and rods. Good shape, timing belt damaged the 2 others $20 for both.
Mk 4 brake master and ABS control unit $15 for the master, $75 for the ABS unit
large ridiculous volvo gasser intercooler. Will hold up to 15 lbs, but think of how much cooling! $ 40
Pick a water pump ! 1 old style 2 newer, all good, $10 each
2 special shaped diesel coolant hoses $5 each
2 turbo intakes, 1 with vacuum hose fitting for LDA, 1 with large breather inlet, both $15, 2 turbo exhausts, 1 TD [sorry don't which kind] $15,other is a JX/Quantum style $65
power steering pumps and brackets,1 older alternator bracket $20,the pump and bracket set $100, TDI ps pump $30
covers $10 for lower cover, $5 valve cover [with the 2 reinforcements]
manual clutch cable ,dipsticks $5 each
Turbo oil feed lines, 1 is AAZ 1 is 1.6TD $15 each
had an accident in the front? here's a front mount bracket $7
1.6 na head. good shape,straight and came from motor with good compression $65 [i will remove the manifold to ship]
Crank breather ,vanagon diesel oil filler $15 each fIller neck SOLD
and finally good used crank bolt $50  ;D
« Last Edit: September 17, 2009, 06:18:00 am by the caveman »
Reply #1August 01, 2009, 09:42:28 am
Re: All kinds of diesel parts for sale
« Reply #1 on: August 01, 2009, 09:42:28 am »
I guess since you posted it I will take the oily looking TD intake with the LDA hose fitting. And I would love to have that crank bolt, but I already got some so someone else is going to be the lucky one  ;)
I will send a PM as well.
Reply #2August 01, 2009, 01:22:28 pm
foxracer1
  • 991
« Reply #2 on: August 01, 2009, 01:22:28 pm »
Interested in both turbos and the aaz head. How much is shipping to 43402?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #3August 02, 2009, 06:29:27 pm
dieselherb1
  • 354
« Reply #3 on: August 02, 2009, 06:29:27 pm »
I can use the ALH valve cover, how much for shipping 22427?
Reply #4August 02, 2009, 10:25:33 pm
turbosuzi
« Reply #4 on: August 02, 2009, 10:25:33 pm »
PM sent
Reply #5August 13, 2009, 08:17:44 pm
foxracer1
  • 991
« Reply #5 on: August 13, 2009, 08:17:44 pm »
pmed
interested in the quote email me [email protected]
91 S10 305 TPI T56
Reply #6August 13, 2009, 09:50:06 pm
stomperz71
  • 52
« Reply #6 on: August 13, 2009, 09:50:06 pm »
PM Sent!!
Reply #7August 14, 2009, 01:49:19 am
blackdogvan
  • 574
« Reply #7 on: August 14, 2009, 01:49:19 am »
Pm sent for the vanagon oil filler!
1991 Vanagon 1.9 mTDI
Reply #8August 14, 2009, 09:13:49 am
nighthippie
  • 14
« Reply #8 on: August 14, 2009, 09:13:49 am »
still have newer water pump?  does the pump work and is the thermostate in the pump??
1982 Diesel Rabbit
1988 Diesel Jetta
1990 Diesel Jetta
2000 TDI Golf
Reply #9September 17, 2009, 06:19:48 am
  • 1739
Re: MORE !All kinds of diesel parts for sale
« Reply #9 on: September 17, 2009, 06:19:48 am »
Sorry .Just replying to myself to bring this post back to the top
Reply #10September 17, 2009, 03:38:17 pm
foxracer1
  • 991
« Reply #10 on: September 17, 2009, 03:38:17 pm »
Parts recieved and as described  A++
91 S10 305 TPI T56
Reply #11September 19, 2009, 10:30:49 pm
85golff
« Reply #11 on: September 19, 2009, 10:30:49 pm »
sent you a message..
Reply #12September 20, 2009, 08:22:14 am
  • 1739
« Reply #12 on: September 20, 2009, 08:22:14 am »
Thanks for the endorsement !
Reply #13September 22, 2009, 06:58:07 am
16vt rabbit
« Reply #13 on: September 22, 2009, 06:58:07 am »
hello, i'm interested in the 1.6l na head. i need one with 12mm head bolts and solid lifters and no cracks between the valves
thanks
Reply #14September 22, 2009, 09:22:19 pm
Turbinepowered
  • 1206
« Reply #14 on: September 22, 2009, 09:22:19 pm »
I thought ALH valve covers were the three-stud kind like the AAZ?
Polish up that crank bolt if I throw in another $10?  ;D
