Author Topic: New to diesel...  (Read 4748 times)
July 31, 2009, 10:02:12 pm
Vohaul
  • 105
New to diesel...
« on: July 31, 2009, 10:02:12 pm »
with my 93 1.9 turbo diesel Jetta....
I love this thing...850km+ to a tank..runs like a top.....
just a quick question...
After sitting for more than a couple hours, when you start it, it puffs a small bit of white smoke out the tailpipe and runs rough (like its missing) for like 5 seconds....then it smooths right out and has no problems at all until i let it sit for more than a few hours again.....is this a normal "diesel" thing? or something i should be at all worried about?
Also, what is with the gear ratio in 5th gear on this car....(feels like im doing about 3-4000 rpm at 120kmh....) (i wouldnt know exactly as there is a clock where the tach should be:)
Thanks all
Paul
Reply #1July 31, 2009, 10:49:25 pm
Re: New to diesel...
« Reply #1 on: July 31, 2009, 10:49:25 pm »
Look on the bottom of your bell housing and get the 2-3 letter code and then check here: http://www.scirocco.org/gears/
Reply #2August 04, 2009, 11:37:48 am
« Reply #2 on: August 04, 2009, 11:37:48 am »
you should probably change the fuel filter.  there could be a little bit of air entering the lines when you let the car sit, and the rough running is just the purging of the air.
Reply #3August 10, 2009, 03:36:05 pm
Rabbit TD
  • 840
« Reply #3 on: August 10, 2009, 03:36:05 pm »
It's amazing how much these things can smoke from excess fuel and burning oil like they do and still get mileage as good as a new Prius.
Reply #4August 11, 2009, 06:58:53 pm
« Reply #4 on: August 11, 2009, 06:58:53 pm »
and with our cars, any blind dude will know to run when he/she hears us coming, but not from the prius...  especially if the driver is busy watching the mileage display  ::) ;D
Reply #5August 12, 2009, 06:36:08 am
stewardc
« Reply #5 on: August 12, 2009, 06:36:08 am »
The smoke and rough idle at startup are normally glow plugs (1 or more is burned out). Do the engine a favour and replace all of them.
Reply #6August 21, 2009, 06:34:30 pm
Rabbit TD
  • 840
« Reply #6 on: August 21, 2009, 06:34:30 pm »
You're right, I work with a lady that has a Prius.  She says she is always scaring people in parking lots like Wal-Mart and isn't even trying to.  They definately hear and smell me around them ;D
