Author Topic: New Pre Chambers Available?  (Read 34732 times)
July 29, 2009, 06:40:54 am
myke_w
  • 1099
« on: July 29, 2009, 06:40:54 am »
So - I know this has been asked before but I figured I'd stir the topic since it's been a while.
Does anybody have any news leads on new prechambers?
Reply #1July 29, 2009, 07:41:47 am
arb
Re: New Pre Chambers Available?
« Reply #1 on: July 29, 2009, 07:41:47 am »
Seams like some enterprising individual might start casting them from HMS-1011 or some other air-melt super alloy ;-)  (Ni Cr Co)
Reply #2July 29, 2009, 09:35:45 am
Turbinepowered
  • 1206
« Reply #2 on: July 29, 2009, 09:35:45 am »
I know I'd be willing to pay $15-$25 each for good new prechambers... less is better, but that's about where my max price has to sit. I would buy plenty, though...
Reply #3July 29, 2009, 10:28:20 am
arb
« Reply #3 on: July 29, 2009, 10:28:20 am »
When I made this type of metal (certified version) it was sold for $100 per pound in 1985. They had a "Renee" (french for reborn I was told) version for much less. The castings and machining (grinding not turning) would be the real cost.
If you could get an accurate 3D CMM of the chambers inside & out, molds could be made easily from stereolithograchic processes
 http://www.stereolithography.com/
There are many casting companies out there to do the casting
http://www.thomasnet.com/products/castings-plaster-mold-process-12421202-1.html
Reply #4July 29, 2009, 03:42:02 pm
Turbinepowered
  • 1206
« Reply #4 on: July 29, 2009, 03:42:02 pm »
That mean I'm pinching pennies too tight and need to loosen up on cost? :p
Reply #5July 29, 2009, 04:26:53 pm
tSoG-84bit
  • 188
« Reply #5 on: July 29, 2009, 04:26:53 pm »
A club member is a damn fine machinist. Get me prints, and I'll see if his shop can quote a run of them. 100 units? 1000? It's a small shop, but well equipped, so I can't imagine it'll be cheap, but I'll see. He was gonna try and reverse engineer some super nozzles for me, but I've yet to find a NOS unit that he can work from.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #6July 29, 2009, 08:46:41 pm
stomperz71
  • 52
« Reply #6 on: July 29, 2009, 08:46:41 pm »
Crazy Question I have!! ;D
When you talk prechambers, what are you refering to? I just removed my head and was told if theirs cracks in the prechambers its junk!
Thanks
Reply #7July 29, 2009, 08:57:16 pm
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #7 on: July 29, 2009, 08:57:16 pm »
Pre chambers are the round things in this picture below the valves. Has a littel hole in it. Its where the injectors squirt into. all the fuel and air "swirl" around and then get compressed and go boom. ha. they also go by swirl chambers hence the "swirl"
1979 VW Rabbit Diesel L
Reply #8July 29, 2009, 09:51:55 pm
stomperz71
  • 52
« Reply #8 on: July 29, 2009, 09:51:55 pm »
Thank you for that!
Would that be the same as precups? I've heard that term used also.
Now are the cracks obvious? Where would they be? The only cracks I seen on my head were between the valve seats.
Reply #9July 30, 2009, 12:17:34 am
rabbid79
  • 684
« Reply #9 on: July 30, 2009, 12:17:34 am »
The terms precups and swirl chambers are somewhat sononymous.  In the VW "swirl chamber", the fuel is directed toward the outer wall of the chamber creating a swirling motion.  In a "precombusion chamber", the fuel is directed pretty much toward the center of the chamber and doesn't create a distinct swirl.  I believe the older IDI Mercedes-Benz engines use this technique.
As for the "precup cracks", they generally go between the valve recesses and the swirl chambers.  Sometimes they're in the swirl chamber inserts themselves.
'15 WRX
Reply #10July 30, 2009, 09:21:10 am
myke_w
  • 1099
« Reply #10 on: July 30, 2009, 09:21:10 am »
If that's the case I'd be glad to send him some good ones to copy?
Reply #11July 30, 2009, 12:48:10 pm
« Reply #11 on: July 30, 2009, 12:48:10 pm »
I'm pretty sure topline makes their own pre chambers, they make heads,cams, valves all that stuff for these diesel's so I wonder if someone could pull some strings and just buy a bunch of pre chambers? ;)
Reply #12July 30, 2009, 01:48:21 pm
myke_w
  • 1099
« Reply #12 on: July 30, 2009, 01:48:21 pm »
Thanks for the tip - I just got off the phone with topline and I may be doing business with them for the chambers. I'll update the thread when I have more info. ;)
Reply #13August 04, 2009, 09:33:50 am
arb
« Reply #13 on: August 04, 2009, 09:33:50 am »
Looking forward to the info :-)
Reply #14August 04, 2009, 11:12:31 am
burnt_servo
  • 278
« Reply #14 on: August 04, 2009, 11:12:31 am »
if they make their own heads , could it be possible that  the precups only fit their heads and not oem vw heads ?
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
