Author Topic: Lifter tick under load?  (Read 3815 times)
July 26, 2009, 06:40:24 pm
Rich_91
  • 21
« on: July 26, 2009, 06:40:24 pm »
Is it possible for lifters to click / tick, but only under load?
Im asking, since i have a clicking / ticking that is fairly noisy when I am driving along, most noticible when accelerating, but it seems to be there all the time.
When I am parked, and have my head under the hood, I cannot duplicate the sound, no matter how i rev the motor. Otherwise the car is running fine.
It wasnt there on the way to work on tuesday, and on the way home I heard it.
No oil consumption before or after (just a tiny headgasket leak that has been around for 1.5yrs. Im not even adding oil between changes.
I am significantly overdue for an oil change, but I cannot see how this would do anything.
Ive tried the "mexican tune-up", with no success  :P
Is there some way maybe to unstick a lifter (if thats even it?)
Car is a 91 Jetta 1.6td
Thanks for the advice..
My Fleet
91 VW Jetta 1.6td.  310K+  My Daily
90 Dodge Ram 50 2.4 turbo (my toy)  250K+
94 Eagle Talon Tsi AWD. 205K+  Another Project!
Reply #1July 26, 2009, 07:35:42 pm
burnt_servo
  • 278
Re: Lifter tick under load?
« Reply #1 on: July 26, 2009, 07:35:42 pm »
check your oil pressure  at the head .
 there should be a sending unit on clutch side of the head that you can pull out and screw in a mechanical guage .
what can happen is as your rpms rise , the pressure can drop to the point that the lifters start to clatter .
i had this happen to me a couple years ago , ended up dropping the pan  replacing the the rod and main bearings and installing a 36mm oil pump .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #2July 29, 2009, 06:11:53 pm
bigblockchev
  • 271
« Reply #2 on: July 29, 2009, 06:11:53 pm »
Change the oil and filter!! It is the cheapest thing to try. On old detroit iron this was a standard first remedy. The old oil is broken down and very thin so it is harder to maintain oil pressure. If this makes a difference you may have worn clearances elsewhere in the engine as others have suggested. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #3July 30, 2009, 03:07:15 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #3 on: July 30, 2009, 03:07:15 pm »
Can also be a blown gasket where the exhaust manifold (header?) bolts to the head. Dangle your fingers and feel for the jets of gas. Hot! :P
