Author Topic: lightened fly wheels  (Read 5139 times)
July 26, 2009, 02:33:11 pm
« on: July 26, 2009, 02:33:11 pm »
i'm getting my hybrid motor built, should i get my flywheel lightened? or does it make it run rougher
Reply #1July 26, 2009, 03:29:27 pm
Re: lightened fly wheels
« Reply #1 on: July 26, 2009, 03:29:27 pm »
also does anyone have an idea of how much it cost to have your bottom end balanced
Reply #2July 27, 2009, 02:09:37 am
« Reply #2 on: July 27, 2009, 02:09:37 am »
flywheel, do it.
balancing, do it yourself, its good practice. professionals will charge way way too much for the amount of work required.
Reply #3July 27, 2009, 08:54:34 am
arb
« Reply #3 on: July 27, 2009, 08:54:34 am »
flywheel, do it.
Manual flywheel ?
Yeah, if you're talking about static balancing, get a "drug dealer's" scale and do it yourself. If you want a real balance, start with the static balance and pay a pro to do a dynamic balance. Then you'll have a smooth engine, but likely making your flywheel lighter will negate and smoothness you got from the dynamic balancing.
Reply #4July 27, 2009, 10:13:15 am
ryanp
  • 269
« Reply #4 on: July 27, 2009, 10:13:15 am »
are there any links to static balance how to's?? i'd love to have a crack!
Cheers
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #5July 27, 2009, 10:34:45 am
arb
« Reply #5 on: July 27, 2009, 10:34:45 am »
Cheers
Ryan
There have been a number of books written on "Blue printing your engine" - basically, you weigh the 4 pistons, and shave a bit off the skirts of the 3 heavier ones until they are within 0.1g (or how ever close you want to get) and same with each moving component (rods, caps, etc) Some guys even do the valve train, but I think that's a bit over the top.
You might find this on the net too.
Reply #6July 27, 2009, 05:43:04 pm
Rabbit TD
  • 840
« Reply #6 on: July 27, 2009, 05:43:04 pm »
I think that the RPM's these run it's really not necessary and these things are gonna have some vibration no matter what, and balancing is not making one thing stronger which is what I would worry about if I was going to try to make a bunch of HP.  I'd spend that money on something that would make a known difference like a Giles pump or something of that nature.
Reply #7July 27, 2009, 08:20:00 pm
« Reply #7 on: July 27, 2009, 08:20:00 pm »
balancing is supposed to be only 100-200 to have done. getting the crank balanced, then doing a static balance is all you need to do on a 4 cylinder since it's in line, but you need the little hangy thing to do the connecting rod, which i'm sure i could rig up... i dunno maybe i will do it.  does a lightened fly wheel really make them rough?  i was only thinking of going down to 8-9 pounds
Reply #8July 27, 2009, 11:30:41 pm
« Reply #8 on: July 27, 2009, 11:30:41 pm »
8 or 9 pounds is way light on a diesel. they usually use those on hot rod revver gas engines. isnt gonna have much torque with that flywheel.
Reply #9July 28, 2009, 01:25:24 pm
« Reply #9 on: July 28, 2009, 01:25:24 pm »
I agree with Libby.
After driving with both OE and lightened flywheels I don't feel there is an advantage to a lightened one at all.
As a matter a fact I think it hurts you off the line.
These little suckers just don't rev fast period and they aren't supposed to either.
Sure you may get a .010 faster time with a lightened flywheel but your going to loos your off the line from a stop sign torque.
Just my 2 cents.
Reply #10July 28, 2009, 03:12:46 pm
« Reply #10 on: July 28, 2009, 03:12:46 pm »
I'd rather have the smoothness of a heavy flywheel. I've heard nonsense like "a light flywheel won't maintain it's speed on a hill as good as a heavy one", but that's wrong, the engine is what's making the power. I guess a light one would help in like 1st and maybe 2nd gear since the rpms are changing fast but after that it's just along for the ride.
Reply #11July 28, 2009, 05:46:58 pm
foxracer1
  • 991
« Reply #11 on: July 28, 2009, 05:46:58 pm »
I have a lightened flywheel and have no complaints. Revs are snappier but not neck snapping.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #12July 28, 2009, 06:21:18 pm
« Reply #12 on: July 28, 2009, 06:21:18 pm »
It is Newton's first law at work...Man I can't believe I just used something I learned at school :D
Reply #13July 28, 2009, 07:37:28 pm
Rabbit TD
  • 840
« Reply #13 on: July 28, 2009, 07:37:28 pm »
I agree with Libby.
Just my 2 cents.
And more than likely the .010 quicker is just due to the car being just a little lighter period.
Reply #14July 28, 2009, 08:01:32 pm
« Reply #14 on: July 28, 2009, 08:01:32 pm »
i get it, they just have more momentum. so it wont die off as much when leaving off the clutch
