Author Topic: Eco diesel or TD?  (Read 3230 times)
July 25, 2009, 09:17:52 pm
aviologist
Eco diesel or TD?
« on: July 25, 2009, 09:17:52 pm »
 So I know from the engine code one can figure out what engine is installed in a vehicle but mine is nearly impossible to see. What was done to a TD to make it Eco diesel and what is the major physical difference between the two. Thanks for your input.
Reply #1July 26, 2009, 02:21:25 pm
Ziptar
  • 565
Re: Eco diesel or TD?
« Reply #1 on: July 26, 2009, 02:21:25 pm »
EcoDiesels have a catalytic converter and an injection pump minus a boost enrichment device, essentially an NA pump. There is no LDA on top of the pump. In place of the LDA on top of the pump there is a ~2" adapter for the fuel line. The engine code is 1Y and they have a K14 turbo (99.9% of them anyway).
http://www.geocities.com/vwecodiesel/overview.htm
« Last Edit: July 26, 2009, 02:24:56 pm by Ziptar »
Reply #2July 26, 2009, 04:00:34 pm
TurboJ
  • 661
« Reply #2 on: July 26, 2009, 04:00:34 pm »
IIRC the Eco-TD also had a 8 mm plunger head, while at least the majority of N/As had 9 mm.
So, the Eco is in need of a pump upgrade if you want to tune it  ;)
Jetta II 1.6 TD 'Project 200'
Reply #3July 26, 2009, 05:24:15 pm
Rabbit TD
  • 840
« Reply #3 on: July 26, 2009, 05:24:15 pm »
How big is the plunger in a 1983 1.6 T/D pump?
Reply #4July 27, 2009, 02:17:57 am
Ziptar
  • 565
« Reply #4 on: July 27, 2009, 02:17:57 am »
That is correct, I forgot about that, mine is an 8mm. An 83 1.6TD should be 9mm. Check the Bosch number on the pump, 0 460 4XX XXX, The 6th digit indicates the plunger size, 8 = 8mm, 9 = 9mm, 0 = 10mm etc..
« Last Edit: July 27, 2009, 02:19:34 am by Ziptar »
Reply #5July 27, 2009, 06:21:38 pm
Rabbit TD
  • 840
« Reply #5 on: July 27, 2009, 06:21:38 pm »
Thank's alot, it's good to know that about the part number, I wonder what the 1.5's used on them ???
Reply #6July 28, 2009, 09:09:51 am
« Reply #6 on: July 28, 2009, 09:09:51 am »
most n/a's just used 9mm pump heads. i think only the Eco used an 8mm pump. all the 1.5's ive played with had 9mm pumps.
Reply #7July 28, 2009, 10:54:01 am
aviologist
« Reply #7 on: July 28, 2009, 10:54:01 am »
Thanks for all the imput folks! Looks like I have the regular old Turbo "Kerosene Queen". With 262000km I should be good for a long ,long time, seeing as my 8V is over 400000km and hardly uses a bit of oil(more leaks out than it burns). Mark
