Author Topic: will this head fit?  (Read 6846 times)
Reply #15July 31, 2009, 02:04:53 pm
Re: will this head fit?
« Reply #15 on: July 31, 2009, 02:04:53 pm »
like we have been saying, a direct injection head fits on a direct injection engine. even if its mechanical or electronic, it will still only bolt to a DI engine. if its mechanical and indirect injection, then it will fit on a 1.6 or an aaz.
so you need to determine if its direct or indirect injection. take a picture. we cant look at your thoughts. lol.
Reply #16August 01, 2009, 02:38:05 pm
curtis1
  • 11
« Reply #16 on: August 01, 2009, 02:38:05 pm »
it looks more like the picture posed by libbybapa, i did get a pic but it was off my phone and isnt very good.. however i did find the engine code out do be AHU.. any ideas guys?
Reply #17August 01, 2009, 02:54:56 pm
Turbinepowered
  • 1206
« Reply #17 on: August 01, 2009, 02:54:56 pm »
AHU is a TDI engine code, so it will not work on an earlier indirect injection engine.
Reply #18August 01, 2009, 05:48:45 pm
« Reply #18 on: August 01, 2009, 05:48:45 pm »
... and it's electronic fuel control.   ;)
Reply #19August 01, 2009, 06:16:23 pm
Turbinepowered
  • 1206
« Reply #19 on: August 01, 2009, 06:16:23 pm »
Using a VE series Bosch pump. :D
Reply #20August 01, 2009, 07:21:05 pm
curtis1
  • 11
« Reply #20 on: August 01, 2009, 07:21:05 pm »
right, thanks guys.. im not tryin to question you as to why it wont work, but could you explain simple terms why it doesnt work? just to build my knowledge a little bit as i am new to these engines..
Reply #21August 01, 2009, 07:35:15 pm
« Reply #21 on: August 01, 2009, 07:35:15 pm »
Probably the easiest way to look at this is to refer to the cutouts I linked to in post #2.
The IDI head has metal inserts that form a pre-combustion chamber... the nozzle squirts fuel into the pre-combustion chamber in the head which burns and pushes out the hole in the prechamber... down goes the piston.
The TDI has no pre-combustion chamber... fuel is injected directly into the combustion chamber formed  by depressions in the piston.
So the heads are totally different and the pistons are total different... and the fuel pump is totally different.
Reply #22August 03, 2009, 10:41:09 am
  • 3468
    • McScrubbins Body Wash
« Reply #22 on: August 03, 2009, 10:41:09 am »
and those godly turbos they come with XD
Reply #23August 03, 2009, 11:01:14 am
« Reply #23 on: August 03, 2009, 11:01:14 am »
most of those godly turbos they came with bolt right on our engines. i think my VNT is pretty godly compared to all my other turbos. i have seen it put out over 35 psi, and it didnt explode. i bet a t/3 or k24 would explode at those boost levels.
