Author Topic: when it rains it pores  (Read 6368 times)
July 22, 2009, 10:08:39 pm
kane66
  • 131
« on: July 22, 2009, 10:08:39 pm »
My Volkswagen just hit the 200000 mile mark and I thought I would celebrate by changing the oil early, and since I had no Idea when the timing belt was done I decided to do that as well.  It also needed a new valve cover gasket as well as the old one had developed a small leak. During my timing belt installation I noticed a bit of diesel on the front of the engine. One of the Injector return lines seamed a little ratty so i figured that was the culprit. So I changed the belt "no small task", and the valve cover during the process. Got everything buttoned up timed and rotated to check for binding and fired her up........ and noticed fuel dripping in a rather quick rate out of the back of the injector pump  >:( >:( >:(..... how is it that I could be blessed with two leaky injector pumps in 2 years. Even though it was leaking I figured it would be good for a few more miles so i drove it to work... with a haze of half cooked diesel fumes surrounding my car. On my way back is when my second misfortune struck... the oil "idiot light" in the dash started flickering a little bit. By time I got home it had become a steady blink..... when I check the oil my dipstick there was nothing on it... It took a quart and a half just to get it into the add oil section.... It doesn't seem to be leaking from any where. I'm really hoping that some of that haze wasn't burning oil. Bad rings ??? I don't know. right now I'm working on removing the injector pump, so I can send it out for a reseal.  In the mean time I'm going to install the POS Prothe pump I have to see if I can get it running well enough to determine where my oil is going. Figures this would all happen just before my tdi swap.
1985 Jetta WBE
Reply #1July 23, 2009, 09:46:17 am
Re: when it rains it pores
« Reply #1 on: July 23, 2009, 09:46:17 am »
Ahh I love old cars. Hopefully you can find the oil problem and it's nothing serious. The drain on the pan is tight?
Reply #2July 23, 2009, 09:52:18 am
« Reply #2 on: July 23, 2009, 09:52:18 am »
you might need to spray the engine down so you can determine the leaky area.  maybe its the valve cover (bent, or whatever)?  leaky pumps really do suck :(  do you have the oil baffle in the head?  they can really help reduce oil consumption.  also make sure that oil isn't leaking on your new timing belt just to be on the safe side...
when did you get the prothe pump?  mind letting us know how it pans out?
Reply #3July 23, 2009, 12:03:45 pm
kane66
  • 131
« Reply #3 on: July 23, 2009, 12:03:45 pm »
 burn_your_money... First thing I checked was the plug, and it was tight, so I'm guessing another culprit.
jtanguay: Defiantly plan on giving it a good spray down with a pressure washer when I get it running again. I got the Prothe pump about 2 years ago.... 2 years of trying to make it work ("hell")... and a thousand dollars later it still doesn't, even though the latest rendition might be gunk from a tank of diesel that had been sitting for to long (my fault). Anyway hoping a bottle of diesel purge will get me back up and running.
1985 Jetta WBE
Reply #4July 23, 2009, 01:37:37 pm
Turbinepowered
  • 1206
« Reply #4 on: July 23, 2009, 01:37:37 pm »
Check your oil filter mount gasket. That's where I was leaking some mad oil on my Quantum, enough to set off that pressure switch that's sitting on the filter mount.
Unless you have the oil-coolant heat exchanger, it's a really easy gasket to replace. Don't strip your socket head screws. :D
Reply #5July 23, 2009, 03:39:14 pm
rallydiesel
  • 1880
« Reply #5 on: July 23, 2009, 03:39:14 pm »
You should do your own pump reseal. It's not that hard, especially if it's just the cold start seal. Then you know what was actually done and you save yourself a boatload of cash.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6July 23, 2009, 07:48:28 pm
« Reply #6 on: July 23, 2009, 07:48:28 pm »
just follow the online pictorial and remember to mark the alignment for the throttle linkage
Reply #7July 23, 2009, 09:58:22 pm
kane66
  • 131
« Reply #7 on: July 23, 2009, 09:58:22 pm »
rallydiesel : jtanguay, I would love to do my own reseal but unfortunately I wont have the time for a week, and I will need my car afterwords. So I'll have to spend the extra money :'( and just have some one else do it. Defiantly not my style, but its hard to live without a car. And mine sure isn't making it easy for me.
Now for updates: Pulled the leaking pump today (man am I getting tired of changing pumps) and installed the Prothe pump. When I pulled the valve cover it was pretty obvious where all the oil had gone... new valve cover seal slipped in on spot and was hanging down into the gally :o. Anyway threw in a used one I had and a oil baffle off of another engine. Rolled it over by hand to insure no binding and tried to bleed the injectors. Ran a battery down before I realized I had forgot to turn the key to the on position. Anyway finally go it bleed and started on the Prothe pump ( at least it will idle) and ran the diesel purge through it. Noticed a few things. Smokey exhaust. There is defiantly a white smokey quality to the exhaust. Could be unburnt diesel but I have it timed to 98 mm so plenty advanced for it to be smoking. Also while running there is smoke coming from the oil fill cap ??? if I take it off quiet a bit of smoke pores  out. Is that normal  ???. I !REALLY! hope the rings haven't gone south as I have a tdi project to start and I need my IDI to get around in. >:(  Guess I'll be buying a compression testing kit to see what I have going on in the cylinders. Any thought or suggestions are greatly appreciated.
1985 Jetta WBE
Reply #8July 24, 2009, 12:04:12 am
« Reply #8 on: July 24, 2009, 12:04:12 am »
How did you kill a battery without turning the key on ??? I think it's normal to turn the key in order to kill the battery.
For the smoke coming out the oil filler, if you can hold your hand over it without getting soaked pretty quick then I bet it's good, rev it and see what happens.
Reply #9July 24, 2009, 06:54:11 am
kane66
  • 131
« Reply #9 on: July 24, 2009, 06:54:11 am »
Thought that might stump someone. I was using a push button start, strait from the battery to the starter, so no need of a key. Sure makes bleeding the injectors easy if you remember to turn the key to the on run position "activate fuel solenoid".
...rev it and see what happens.....  ;D ::) ;D thats something that prothe pump is good at, it'll rev and hand out there for a few minutes  :o. so I'll have plenty of time to see if I'm getting a lot of oil out of the crank case. I'm assuming soaked with oil is what your referring to. I'm guessing it's not worn rings with the white smoke, as oil in the combustion chamber would cause blue smoke. But maybe a blown head gasket or work valve guides..... ???...... something sure is pressurizing my crank case, as there is also a small stream of oil coming out of the dipstick :(. Again any ideas and suggestions would be appreciated.
1985 Jetta WBE
Reply #10July 24, 2009, 07:02:43 am
92EcoDiesel Jetta
« Reply #10 on: July 24, 2009, 07:02:43 am »
Maybe time for a leak down test?
Reply #11July 24, 2009, 08:02:55 am
« Reply #11 on: July 24, 2009, 08:02:55 am »
getting the rpm's to stop hanging isn't a big deal.  you can either back out the max fuel screw, or play with the residual fuel screw (the idle stop for the throttle linkage)
i think you might need to take this car for an italian tune up... either that or just install new rings.  oil shooting out the dipstick is not right, but very common on worn out 1.6's at high rpms.
« Last Edit: July 24, 2009, 08:05:16 am by jtanguay »
Reply #12July 24, 2009, 10:20:15 am
kane66
  • 131
« Reply #12 on: July 24, 2009, 10:20:15 am »
I actually tried that about a month ago.... you probably where the one who recommended it. What happens is that if I back the fuel screw so far out there is no throttle response and then turn it in a quarter turn it hangs... so essentially no matter where the fuel screw is the pump hangs ???. I called the last diesel shop that looked at it and they recommended I try Diesel Purge. to see if something had "gummed it up" not expecting much but who knows maybe it will work. Anyone know a affordable place to get a reseal with a quick turn-around. It looks like libbybapa has moved on to bigger and better things.
1985 Jetta WBE
Reply #13July 24, 2009, 11:00:55 am
« Reply #13 on: July 24, 2009, 11:00:55 am »
hey kane, do you have an 88 scirocco 16 v? is it white?
Reply #14July 24, 2009, 11:31:52 am
kane66
  • 131
« Reply #14 on: July 24, 2009, 11:31:52 am »
No but that would be sweet.... Im not a member of the 503 area code. I leave way up in the boonies east of Salem.
1985 Jetta WBE
