Author Topic: IP pump Timing  (Read 2413 times)
July 22, 2009, 03:44:35 am
topless96
  • 58
IP pump Timing
« on: July 22, 2009, 03:44:35 am »
Anyone have a link to setting the timing up on a 1.6 td? I am looking for one with photos so i can see as well as read the procedure. Tried some searching but did not find what I was looking for.
Reply #1July 22, 2009, 03:53:18 am
anto
Re: IP pump Timing
« Reply #1 on: July 22, 2009, 03:53:18 am »
This should help a little, some of the pic links are broken i think so you might want to send vince a message see if he can srot them out?
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Reply #2July 22, 2009, 11:24:06 am
derekp
  • 94
Re: IP pump Timing
« Reply #2 on: July 22, 2009, 11:24:06 am »
Vinces directions are GREAT.
I just did my head gasket and timing belt and found it a breeze to do the timing - though I profess to being a bit nervous doing the timing belt thing in a diesel (I've done a bunch of gascar timing belts - but they all just have to "line up the marks")
I must say I'd wished I did a dry run BEFORE I took the car apart so I could know what it was before disassembly but its all back and it runs as well as it did before (uh, the head gasket was leaking oil so it was not replaced due to compression leakage)
Good luck with the job
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #3July 22, 2009, 12:53:18 pm
Re: IP pump Timing
« Reply #3 on: July 22, 2009, 12:53:18 pm »
Hi Anto... there should be no broken links as the entire site is ISP-hosted... so if you're seeing missing pictures I'd love to sic my ISP on the problem!!
Screen capture would be best, since everything looks fine when I view it,  so won't be able to replicate your experience!!
Reply #4July 22, 2009, 07:07:52 pm
topless96
  • 58
Re: IP pump Timing
« Reply #4 on: July 22, 2009, 07:07:52 pm »
Thanks guys, i love this site. Will time tomorrow night.
Reply #5July 22, 2009, 08:50:27 pm
Rabbit TD
  • 840
Re: IP pump Timing
« Reply #5 on: July 22, 2009, 08:50:27 pm »
The single most important thing to do is to turn it over with a socket on the crankshaft about 4 turns to make sure nothing is going to hit anywhere and make sure to take the ratchet off afterwards.  This will also tell you if you forgot to take the cam lock or the pump pin out also, it happens all the time.
Reply #6July 22, 2009, 10:12:08 pm
kane66
  • 131
Re: IP pump Timing
« Reply #6 on: July 22, 2009, 10:12:08 pm »
Or just use the drivers side tire. Added benefit is that you can see the timing mark in the transmission and the dial indicator from there and there's no worries about leaving potentially destructive tools attached to your engine.
1985 Jetta WBE
