Author Topic: kaputtwagen 1982 rabbit AAZ swap/build  (Read 133110 times)
Reply #180May 22, 2017, 07:03:01 pm
jack's lack
  • 275
« Reply #180 on: May 22, 2017, 07:03:01 pm »
Finished blocking the last panel tonight
And hit it with primer.
Next up is the interior, which obviously won't require quite the same level of attention, and a quick wet sanding of the exterior, and then hit it with high-build primer aka spray on filler, then guide coat and block like mad.
« Last Edit: July 15, 2017, 09:16:53 am by jack's lack »
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #181June 01, 2017, 07:42:40 pm
jack's lack
  • 275
« Reply #181 on: June 01, 2017, 07:42:40 pm »
Made some progress on the trunk floor tonight. There are a few small rust holes to weld up, then I'm gonna start working my way forward with POR 15.
« Last Edit: July 15, 2017, 09:14:46 am by jack's lack »
My Build Thread
Reply #182June 05, 2017, 07:39:18 pm
jack's lack
  • 275
« Reply #182 on: June 05, 2017, 07:39:18 pm »
Tonight's progress
Finished cleaning up the trunk floor
And painted it with POR 15.
« Last Edit: July 15, 2017, 09:12:09 am by jack's lack »
My Build Thread
Reply #183June 11, 2017, 07:00:48 pm
jack's lack
  • 275
« Reply #183 on: June 11, 2017, 07:00:48 pm »
I cleaned up the floor below the back seat. I had a mess of rust to clean up on the passenger side between the wheel well and the door.
Painted with POR 15.
« Last Edit: July 15, 2017, 09:07:51 am by jack's lack »
My Build Thread
Reply #184June 11, 2017, 07:57:23 pm
Re: kaputtwagen 1982 rabbit AAZ swap/build
« Reply #184 on: June 11, 2017, 07:57:23 pm »
What are you using to remove the paint and rust prior to painting?  A wire wheel on a drill?
Reply #185June 12, 2017, 07:51:58 pm
jack's lack
  • 275
« Reply #185 on: June 12, 2017, 07:51:58 pm »
I tried the wire wheel initially, but it was basically useless. The rubber seam sealer and the carpet glue are just too stubborn for it. The carpet glue is especially a nuisance. If you get it hot, you can move it around, but when it cools it's back to being just as sticky as before.
I have been using one of these in a die grinder to some greater degree of success.
I then follow up with those 2" coarse brown  scotchbrite like disks to get in the tight spots and then do a quick 80 grit sand with the random orbit.
The rear passenger floor pan area is what two hours with the above wheel gets. I'd get more done if I had a bigger air compressor. I'd say I get about a 50% duty cycle with the die grinder.
« Last Edit: July 15, 2017, 09:02:22 am by jack's lack »
My Build Thread
Reply #186June 12, 2017, 08:13:01 pm
« Reply #186 on: June 12, 2017, 08:13:01 pm »
Thanks for the info.  I think I have some of the same to be doing on a Caddy I just hauled home last week.
Reply #187June 13, 2017, 08:39:07 pm
jack's lack
  • 275
« Reply #187 on: June 13, 2017, 08:39:07 pm »
No problem, and happy sanding. A (I assume diesel) caddy! That's a nice find!
My Build Thread
Reply #188June 13, 2017, 08:40:15 pm
jack's lack
  • 275
« Reply #188 on: June 13, 2017, 08:40:15 pm »
Made more progress tonight.
« Last Edit: July 15, 2017, 08:57:17 am by jack's lack »
My Build Thread
Reply #189June 15, 2017, 07:24:07 am
« Reply #189 on: June 15, 2017, 07:24:07 am »
Jack,s lack this should answer you question.
http://vwdiesel.net/forum/index.php/topic,37009.0.html
Honestly are there any others worth having?
Reply #190June 15, 2017, 07:05:23 pm
jack's lack
  • 275
« Reply #190 on: June 15, 2017, 07:05:23 pm »
Very nice! I'd be jealous of the deal you got, but clearly I have my hands full. I'm looking forward to seeing it progress.
But to answer your question, even if it comes with a gasser, you can always swap a diesel in. Caddys are rare enough around here that they are all worth good money.
My Build Thread
Reply #191June 15, 2017, 07:09:44 pm
jack's lack
  • 275
« Reply #191 on: June 15, 2017, 07:09:44 pm »
Tonight's activity.
Uncovered this rust hole. Should be easy enough to patch.
« Last Edit: July 17, 2017, 01:03:43 pm by jack's lack »
My Build Thread
Reply #192June 26, 2017, 08:03:30 pm
jack's lack
  • 275
« Reply #192 on: June 26, 2017, 08:03:30 pm »
Got the next section cleaned up
and painted.
close-up of the rust repair.
 started on the driver's floor pan tonight. There are a couple of rust holes to repair, but they are difficult to make out in the photo.
« Last Edit: July 17, 2017, 01:01:39 pm by jack's lack »
My Build Thread
Reply #193July 06, 2017, 11:58:16 am
  • 5104
« Reply #193 on: July 06, 2017, 11:58:16 am »
photobucket is so greedy, you can barely use their website or app because of all the advertisements and now they want to charge for third party hosting when there are a million other sites who will host for free.
Reply #194July 06, 2017, 02:21:33 pm
« Reply #194 on: July 06, 2017, 02:21:33 pm »
Phuckobucket.  What a dick move...  I'd rather pound screws into my toes than give them any money... ever.
