Author Topic: F/S Rebuilt 1.6na mech.  (Read 3565 times)
July 21, 2009, 01:26:51 pm
veedubcanuck
  • 151
« on: July 21, 2009, 01:26:51 pm »
  I rebuilt this to put in my Suzuki but I don't have the time anymore so here it is:
 Engine has new bearings, seals, water pump,oil pump, timing belt, piston rings valve guides and seals, head gasket, re-built vacuum pump, re-built injector pump. Injectors, heat shields and valve guides were done while the car was on the road and have about 500kms on them. There were no cracks at all between valves. It's a solid lifter(mechanical) motor. At this point there are 0kms on the rebuild. $800 Negotiable.
