Author Topic: What valve covers fit the 1.6 N/A ? My stamped one seems to be warped...  (Read 3921 times)
July 21, 2009, 09:00:27 am
Pre95
  • 81
so i cant get it to stop leaking. Do the 8v gassers work?
81 Rabbit Diesel - 250k and climbing :)
Reply #1July 21, 2009, 09:24:25 am
VW_Commuter
  • 355
I have a pretty nice NA diesel valve cover that I'll let you have for shipping.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #2July 21, 2009, 10:13:05 am
Pre95
  • 81
Tempting, but if it's a stamped steel like this one Im going to have to pass. It looks like a lot of people run the cast G60 valve covers but I have heard it causes an airbox fitment issue...
Reply #3July 21, 2009, 11:47:37 am
yea, it causes the NA air boxes to be in the way of that pretty valve cover. with the stock na intake, you get to use stock stamped steel pretty much.
Reply #4July 21, 2009, 03:12:03 pm
Mark(The Miser)UK
  • 1557
Mark-The-Miser-UK
Reply #5July 21, 2009, 04:23:27 pm
VW_Commuter
  • 355
The only reason they would leak is if you don't reassemble them correctly.  If you use the cork valve cover gasket, you need to use the studs with the shoulder (which prevents the gasket from moving), and then you make sure your metal strips are straight.  Also, make sure you don't exceed the torque spec which is 7.5 ftlbs or 90 inlbs.
If you are going to use the re-usable rubber gasket then you will need to consult the correct Bentley to see the proper assembly sequence and torque spec.
Greg
Reply #6July 21, 2009, 07:03:16 pm
Well, those are your two choices... stamped original or the cast G60.
Reply #7July 22, 2009, 08:22:37 pm
SolarSteve
  • 264
I just went through a bout of leaky valve cover with my stamped one.  I hammered it out and got it to seal with a cork gasket.  It really wasn't that hard to fix.  I just set it on my table saw to see where it was warped and then I placed a piece of 2" wide by 6" long by 1/4" steel in my vice and set the valve cover on it and tapped at it with a hammer until it was fairly straight.
With the help of this site I not only fixed the cover but they also pointed me towards German Auto Parts where I bought a rubber gasket without the shoulders that I will be installing when I hit 1000 miles after the head swap and will re-torque the head bolts.
They are fixable, just take your time.
Steve
91 Jetta 1.6 N/A
Reply #8July 26, 2009, 10:09:25 am
janb
  • 167
Do yourself a favor and use a rubber gasket. ~$7.00, I also use the metal strips (that are along the edges of valve cover) on the studs in such a way to add extra pressure at the ends.  (curve up in center)
You can pop out the brass inserts on the rubber gasket at each bolt hole, OR you can insert studs without shoulders (or turn the shoulders off if you have a lathe).  I have been known to use set screws for studs, just use loc-tite to make them think they are studs  ;D
The Stealth Rabbit
VW-d's are forever
