Author Topic: oil leak from head gasket  (Read 4006 times)
July 18, 2009, 04:36:22 pm
haybayian
  • 155
« on: July 18, 2009, 04:36:22 pm »
I run a recent professionally rebuilt AAZ which showed no leak when I ran it first  from the machine shop last year. I have hardly used it, maybe 2 hours altogether. Now there is an oil leak which seems to originate in the block to head interface on the vacuum pump side. My question: should I check the torque of the cylinder head 10 bolts? Do these normally have to be retorqued after a rebuild?
Thanks.
Haybayian
Keep it simple if you can.
Reply #1July 18, 2009, 05:03:17 pm
Re: oil leak from head gasket
« Reply #1 on: July 18, 2009, 05:03:17 pm »
Normally you don't need to retorque with the metal HG. You can't really check the torque because it's x ft/lbs + 1/2 a turn. It won't hurt to check to make sure they aren't lose though.
Check to make sure it's not a rotted turbo oil feed line or something similar
Reply #2July 19, 2009, 10:14:26 am
haybayian
  • 155
« Reply #2 on: July 19, 2009, 10:14:26 am »
Thanks Tyler for your advice. I will check all this.
Haybayian
