Author Topic: How fast is your veggie burner? Come find out!  (Read 3462 times)
July 15, 2009, 07:32:28 pm
sdwarf36
  • 159
« on: July 15, 2009, 07:32:28 pm »
August 1st-2nd Killington sports car club will be holding a hillclimb at Okemo Mount in Ludlow, Vt. We will be having a special "alternative fuel class" for Veg burning + BioD cars.
A hillclimb is a timed run up a course (this one is 2.7 miles with 30 turns) one car at a time against the clock.
You can get more details about our events at www.hillclimb.org
Greasecar will be setting up a display-and Greasecar president + owner Justin Carver will be there tearing it up with his Mtdi powered Rabbit.
What you need to pass tech is a sound car (a bit of common sense-check your car for a loose battery-bad wheel bearings etc.) An A-B-C fire extingusher mounted within reach - a Snell SA 2000 --(NOT a "M' certified one! Look for the tag.) and if you have an above floor tank secured with straps, it also needs some form of secure bracing to prevent movement.
We have Bio burning TDI's running with us and are pretty quick.
Any questions you can contact me at:
[email protected].
Sherman Baumann
KSCC President ( and fellow greaseburner)
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
