Author Topic: My horn keeps blowing fuses---any ideas?  (Read 3980 times)
July 13, 2009, 06:58:49 pm
mtnbob
  • 738
« on: July 13, 2009, 06:58:49 pm »
Any suggestions on where to start looking. When I put a fuse in the horn works for a minute then blows the fuse again. :(
96 Subaru Outback Wagon
Reply #1July 14, 2009, 05:42:49 am
Re: My horn keeps blowing fuses---any ideas?
« Reply #1 on: July 14, 2009, 05:42:49 am »
Check the ground wire that is attached to the steering column/rack in the engine bay.  That is the ground for the horn.  If that wire is mangled, there might be too much resistance when the horn is pressed blowing out the fuse.  That wire gets mangled a lot from people swapping out racks or dropping transmissions.  :)
Reply #2July 14, 2009, 06:59:34 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #2 on: July 14, 2009, 06:59:34 pm »
I don't know about the 86, but on the 91 the horn fuse also handles cooling fan, so you could have issues in that circuit.  If it only blows when you are actively using the horn, there could be a short inside your steering wheel/column.
« Last Edit: July 14, 2009, 07:01:25 pm by clbanman »
Calvin
91 VW Golf 1.6NA 5spd
