Author Topic: Needed: oil dipstick metal tube for 1Z  (Read 3829 times)
July 13, 2009, 06:41:43 pm
fairweather
  • 85
    • TDI Syncro
« on: July 13, 2009, 06:41:43 pm »
Anybody got one?
TIA, Tom
Pls. email direct:
tom.verry at gmail.com
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #1July 13, 2009, 08:43:55 pm
Syncroincity
  • 727
Re: Needed: oil dipstick metal tube for 1Z
« Reply #1 on: July 13, 2009, 08:43:55 pm »
Are you looking for car or van fitment?
I have the car-type tube from my AAZ... that should fit the fit the 1Z, unless they changed the bolt position...
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2July 14, 2009, 05:50:02 am
fairweather
  • 85
    • TDI Syncro
« Reply #2 on: July 14, 2009, 05:50:02 am »
It is going in a van but I have a tube from a 1.6 I think that I thought would fit but it's too skinny. So I thought to weld the 1z base to the upper part of the DV tube.
So the AAZ tube should work for the base where it goes into the block.
How much?
Thanks, Tom
Reply #3July 14, 2009, 06:07:48 pm
Syncroincity
  • 727
« Reply #3 on: July 14, 2009, 06:07:48 pm »
Uh-oh... then I may have the same problem; I have a DV dipstick coming from Germany, but you're saying the base of the tube is too small for the 1.9 block? ???  Scheise... I guess I'll have to hold onto the AAZ tube until I see for sure, sorry.
See kids, this is why you don't throw anything away until the conversion is complete ::) I already had to buy a new oil cooler after finding the one on the AAZ crushed by the motor resting on the filter... and I had just shipped the old wasserleaker off to the scrapyard with the oil cooler still on it.
« Last Edit: July 14, 2009, 06:13:17 pm by Syncroincity »
JC McCavitt
'98 Jetta Wolfie
Reply #4July 14, 2009, 07:12:41 pm
fairweather
  • 85
    • TDI Syncro
« Reply #4 on: July 14, 2009, 07:12:41 pm »
Yep, got it from Vanagon Jurgen (my bad though, didn't have a clue), the base is too small. If my research is accurate you need it from a later (83.5+) DV.
Reply #5July 19, 2009, 08:15:38 pm
Syncroincity
  • 727
« Reply #5 on: July 19, 2009, 08:15:38 pm »
Ok, we'll see what shows up...
JC McCavitt
'98 Jetta Wolfie
