Author Topic: 2001 TDI Beetle  (Read 3039 times)
July 04, 2009, 04:58:15 pm
toddzil
  • 1
2001 TDI Beetle
« on: July 04, 2009, 04:58:15 pm »
Need a little help trouble shooting my wifes car.  2001 TDI Beetle started to jerk real hard and blow black smoke.  The car won't get over 25 mph and dies.  I was thinking mass air flow sensor, fuel pump or filter, etc.  Any help would be greatly appreciated.  newbielink:mailto:[email protected] [nonactive]
Reply #1July 04, 2009, 04:59:30 pm
catlin_cava
  • 1954
Re: 2001 TDI Beetle
« Reply #1 on: July 04, 2009, 04:59:30 pm »
I'm not a big expert but it sounds like the turbo went. Do you hear the turbo when the car is running?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #2July 06, 2009, 12:38:53 pm
gigaz2
  • 626
Re: 2001 TDI Beetle
« Reply #2 on: July 06, 2009, 12:38:53 pm »
you need to read the codes out of that thing, usually the ecu will tell you whats wrong
Reply #3July 06, 2009, 05:06:17 pm
Quantum TD
  • 1195
Re: 2001 TDI Beetle
« Reply #3 on: July 06, 2009, 05:06:17 pm »
Check fueling first. Replace filter if that's never been done.
Do you run alternative fuels? That can cause problems.
If you have no boost, then your N75 valve may be bad. It controls the wastegate. If it's not working, you will have no boost. Even with a bad one, you should still be able to go over 25 MPH and not buck.
Sounds like a fueling issue.
