Author Topic: How to tell if Injection Pump is Bad?  (Read 12791 times)
June 30, 2009, 04:14:32 pm
Doakster
  • 291
« on: June 30, 2009, 04:14:32 pm »
What's  the best way to tell if your injection pump is going bad? Can you check the output pressure some how?
I've been trying to track down a mileage issue for some time now. Rebuilt injectors are going back in this week, IP timing is good just checked it tonight, fuel filter is new, turbo does have oil around it and I can't figure out where it's coming from, going to put a new air filter in and check the compression tomorrow.
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #1July 01, 2009, 05:48:58 am
ilikevwdiesel
  • 1202
Re: How to tell if Injection Pump is Bad?
« Reply #1 on: July 01, 2009, 05:48:58 am »
hey I'm in Maine where are you at?
My Bio
Reply #2July 01, 2009, 06:09:11 am
maxfax
  • 2126
« Reply #2 on: July 01, 2009, 06:09:11 am »
Unless the pump is leaking, preocess of elimination is best way of checking the pump, short of pulling it and having someone check it on a test bench...
Reply #3July 01, 2009, 07:08:22 pm
Doakster
  • 291
« Reply #3 on: July 01, 2009, 07:08:22 pm »
I'm a ways north...Lincoln area
Reply #4July 01, 2009, 07:10:26 pm
Doakster
  • 291
« Reply #4 on: July 01, 2009, 07:10:26 pm »
So what's the process of elimination, i've tried just about every thing short of pulling the turbo and having it rebuilt.
Also checked the compression tonight...all good at around 440-450 psi
Reply #5July 02, 2009, 06:17:33 pm
Rabbit TD
  • 840
« Reply #5 on: July 02, 2009, 06:17:33 pm »
I've  read on here numerous times that when mileage starts dropping off and the motor seems to have no other problems that air getting in the fuel line to the pump is a good cause for this, that's where the clear fuel line from the filter to the pump comes in handy.
Reply #6July 03, 2009, 12:29:18 pm
Doakster
  • 291
« Reply #6 on: July 03, 2009, 12:29:18 pm »
Funny you say that because I do get an air bubble going from he filter to the pump every once in awhile, I just put on new rubber hoses on that line, but I'll have to check again.
Also with my new rebuilt injectors my mileage went from 30ish up to 35ish....still not the same as my 43 I was previously getting
Reply #7July 03, 2009, 03:49:34 pm
92EcoDiesel Jetta
« Reply #7 on: July 03, 2009, 03:49:34 pm »
Do you have a fuel leak somewhere? How about the odometer? Have you verified that it is not slipping and counting every mile? Air can get in from bad seals in the IP. I was seeing bubbles in the clear fuel line. I also had a leak in the distributor head o-ring. I replaced that o-ring and the leak is gone as well as the bubbles.
Reply #8July 03, 2009, 04:25:49 pm
Doakster
  • 291
« Reply #8 on: July 03, 2009, 04:25:49 pm »
I verified the mileage on a GPS, it's within a half a MPH.
Also false alarm on the bubbles, I had observed that just after I finished the install on the injectors, so it was working the air out, no bubble now.
I am still completely stumped. It's frustrating when I read a bunch of posts about people getting around 45mph no prob with and ECO, I had that once, but can't seem to get it back.
Reply #9July 03, 2009, 04:31:58 pm
Powered by Spearco
  • 1203
« Reply #9 on: July 03, 2009, 04:31:58 pm »
Here's a stupid question, but does your throttle cable need adjusting? ::)
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10July 03, 2009, 05:04:28 pm
Doakster
  • 291
« Reply #10 on: July 03, 2009, 05:04:28 pm »
Well I don't think so...I can cruise fine 60-75 on the highway no problem....throttle works smooth. How are you relating throttle cable to a mileage issue?
Reply #11July 04, 2009, 04:01:53 pm
Rich_91
  • 21
« Reply #11 on: July 04, 2009, 04:01:53 pm »
I am having exactly the same issue. I have no visible fuel leaks, and I am wondering if one of the IP seals is sucking air somehow?
Im not sure how to test this though.
My milage is around 6.7L / 100km  :(
Are your injectors original or quite old? I did get an increase in power and milage when I replaced mine last fall, but my fuel milage is still well below what it should be.
My Fleet
91 VW Jetta 1.6td.  310K+  My Daily
90 Dodge Ram 50 2.4 turbo (my toy)  250K+
94 Eagle Talon Tsi AWD. 205K+  Another Project!
Reply #12July 04, 2009, 04:45:15 pm
Doakster
  • 291
« Reply #12 on: July 04, 2009, 04:45:15 pm »
Injectors are freshly rebuilt, just put them in a few days ago. Mileage only increased from 30 to 35 mpg, I've verified there is no fuel leaks to and from the pump, no air bubbles are visible what so ever in the clear lines.
I just inspected my turbo piping, and reinstalled with RTV sealer at the hoses...we'll see if that helps.
Reply #13July 05, 2009, 11:21:40 am
Rabbit TD
  • 840
« Reply #13 on: July 05, 2009, 11:21:40 am »
[/quote
From what I've seen they almost always have slack in them and keep it from going to full throttle.
Reply #14July 05, 2009, 03:25:47 pm
Doakster
  • 291
« Reply #14 on: July 05, 2009, 03:25:47 pm »
[/quote
Just verified I can go to full throttle....with the peddle all the way down the throttle arm on the pump bottoms out on the adjustment screw before it hit the peddle stop inside the car.
I've always run this car no more than 60-70 mph freeway, and have always had more throttle to go.
