Author Topic: Is this exhaust OEM?  (Read 3795 times)
June 30, 2009, 12:31:34 pm
92EcoDiesel Jetta
« on: June 30, 2009, 12:31:34 pm »
Is this the catalytic converter? Is it OEM?
Reply #1June 30, 2009, 12:57:10 pm
GEE-BEE
  • 1604
Re: Is this exhaust OEM?
« Reply #1 on: June 30, 2009, 12:57:10 pm »
it's the oem model....
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2June 30, 2009, 01:01:32 pm
« Reply #2 on: June 30, 2009, 01:01:32 pm »
there are way too many catalysts and mufflers on that exhaust system. cut it off in front of the cat and call it good. should gain you a bunch of power.
Reply #3June 30, 2009, 01:02:40 pm
92EcoDiesel Jetta
« Reply #3 on: June 30, 2009, 01:02:40 pm »
I wonder if that cat converter is plugged up? Anyway to tell without pulling it apart?
Reply #4June 30, 2009, 01:53:33 pm
« Reply #4 on: June 30, 2009, 01:53:33 pm »
cut it off and shine a flash light through it. then weld a piece of pipe in place where it used to be. lol
Reply #5July 01, 2009, 05:46:39 am
ilikevwdiesel
  • 1202
« Reply #5 on: July 01, 2009, 05:46:39 am »
That cat is stock to Eco diesels sold in the US. Remove the whole thing and replace it with Bosal 783-309. You should be able to find that number online for cheap.
My Bio
Reply #6July 01, 2009, 10:08:26 am
92EcoDiesel Jetta
« Reply #6 on: July 01, 2009, 10:08:26 am »
Is this it? Does it replace the cat section only, keeping the 2 mufflers?
http://www.amazon.com/Bosal-783-309-Front-Pipe/dp/B000CEZFWC
Reply #7July 01, 2009, 01:46:23 pm
ilikevwdiesel
  • 1202
« Reply #7 on: July 01, 2009, 01:46:23 pm »
yep that's it.
My Bio
Reply #8October 08, 2009, 06:32:37 am
92EcoDiesel Jetta
« Reply #8 on: October 08, 2009, 06:32:37 am »
I haven't done anything with the cat yet. Has anyone gutted the inside of cat in place and then sealing it up? Much less work then putting in a new down pipe, which requires new parts, special muffler clamp tool and welding- none of which I have. This should clear out any blockage/restriction in the cat. It'd be interesting to see how much performance increase afterwards.
Reply #9October 09, 2009, 12:02:47 am
« Reply #9 on: October 09, 2009, 12:02:47 am »
Yeah my Dad pulled the guts out of his eurovan cat like that, wacked a hole in the side. Welding it up didn't work so good though, he's not an arc or wirefeed kinda guy (does oxyacetalean) so it didn't seal up and there's some exhaust noise up front.
Reply #10October 10, 2009, 08:06:23 am
macka
  • 957
« Reply #10 on: October 10, 2009, 08:06:23 am »
yea, I pulled one off of my old truck and poked an iron bar through the holes, then the guts pretty much fell out. then I put it back on. The best part is, it passed emmissions 3 times.  :D
Quote from: Vincent Walden
Reply #11October 10, 2009, 04:03:51 pm
VelocityConservation
  • 92
« Reply #11 on: October 10, 2009, 04:03:51 pm »
We have always just driven a piece of pipe through the innards (sic) of the cat.
I have set of old motorcross handlebars that even let me work around some some corners.
The first "muffler" in the rest of your system is a resonator.  It does not restrict the exhaust flow.
If your state inspection will allow it, I put 2.25" tube from the downpipe to a high-flow muffler in the stock muffler location.  That dropped EGT's significantly.
90 TD Jetta, NA to TD swap completed '07
Reply #12October 11, 2009, 09:28:18 am
« Reply #12 on: October 11, 2009, 09:28:18 am »
catastrophic converters are a waste of time. i dont own a vehicle with one. thats the first mod that every one of my rigs get. my toyota came alive when i de-catted it.
