Author Topic: What IP do I have? N/A or TD  (Read 5295 times)
June 29, 2009, 07:06:54 pm
SolarSteve
  • 264
« on: June 29, 2009, 07:06:54 pm »
I have a 1991 Jetta 1.6 N/A but my IP has the "spaceship" diaphram thing on top.  Is this a TD pump?
I just aquired a 1990 1.6 N/A complete motor and the IP on that one does not have the spaceship.  This came out of a 1990 Golf.
Thanks
Steve
91 Jetta 1.6 N/A
Reply #1June 29, 2009, 07:17:44 pm
Re: What IP do I have? N/A or TD
« Reply #1 on: June 29, 2009, 07:17:44 pm »
Most likely it's an ALDA which reduces the fueling at low atmospheric pressure, like climbing a mountain.
Reply #2June 29, 2009, 08:11:22 pm
SolarSteve
  • 264
« Reply #2 on: June 29, 2009, 08:11:22 pm »
If I am climbing a mountain why would I want to reduce fueling?  Wouldn't I want more fuel to help me up the mountain?
The other IP that I have does not have the spaceship.  Is that a better pump?
Thanks
Steve
91 Jetta 1.6 N/A
Reply #3June 29, 2009, 08:17:26 pm
« Reply #3 on: June 29, 2009, 08:17:26 pm »
Thanks
When your climbing the oxygen is getting thinner so you can't burn all that fuel anyways, that's when a turbo would come in handy 8).
Reply #4June 30, 2009, 04:44:06 am
« Reply #4 on: June 30, 2009, 04:44:06 am »
Take a picture of the pump and post it if you can.
Whichever pump runs better on the engine is the better pump. In stock, freshly rebuilt form they basically the same AFAIK
