Author Topic: Need to get home. Please help  (Read 6530 times)
June 24, 2009, 06:27:07 pm
shari
  • 13
« on: June 24, 2009, 06:27:07 pm »
So hi I really need ya'lls help. Im in new Mexico on my way to north Carolina and am needing your collective minds. Here is the tale. So I on tuesday I stopped for the night and I had been checking my fan periodically and it seemed intermittant and all wire connections in the car that could jiggle lose pretty much had. So when checking I fooled with the connection at the thermo switch and the fan came on. I restripped the wires and reconnected them. Drove for a half hour the next day,  and stopped to check the fan. Wasn't on and then coolant started spraying out the expansion tank. While waiting for a tow I checked the fan fuse and realized it was blown and that I had probably reversed the connection. So I got towed to a parts store and have ordered a tank, thermo switch, and thermostat to be safe and have looked at some things in the two days I've had to wait for the parts. The coolant is circulating, there is no
Oil in coolant or vice versa, there is a very small amount of bubbles (hardly any) in the expansion tank while running, I can hotwire fan both at fan and switch and it works. So my questions: do you guys think that if I put the new tank in and thermo switch that I can keep driving? Is it just the fact. That I stopped and didn't have the extra wind blowing through the radiator that the expansion tank burst? Thank you. So much for your help. I really need it and appreciate it. Oh by the way in weld does not
Work on your expansion tank.
shari
Reply #1June 24, 2009, 07:31:36 pm
Re: Need to get home. Please help
« Reply #1 on: June 24, 2009, 07:31:36 pm »
If the t-stat is failing I don't think the fan will come on since no hot water will get to the thermo switch in the rad. Good luck, let us know what happens :)
Reply #2June 24, 2009, 07:52:28 pm
shari
  • 13
« Reply #2 on: June 24, 2009, 07:52:28 pm »
hi. i checked the hoses and the radiator and the were warm. i wasnt sure how long to run it to do that and was scared of running it too long in its condition. the top hose was warm.
shari
Reply #3June 24, 2009, 07:54:54 pm
« Reply #3 on: June 24, 2009, 07:54:54 pm »
If you have bubbles in the expansion tank when the car is running you have a blown headgasket.
You can try and limp it home, but you risk damaging the engine. When you are moving the fan pretty much never comes on.
Reply #4June 24, 2009, 08:05:49 pm
« Reply #4 on: June 24, 2009, 08:05:49 pm »
Won't a blown HG with that symptom also cause high running temps?
Reply #5June 24, 2009, 08:35:03 pm
shari
  • 13
« Reply #5 on: June 24, 2009, 08:35:03 pm »
i dont have a temp gauge. it near one
hundred degrees outside. would just a few tiny
bubbles be enough to indicate a blown head
gasket? whay would the expansion tank start
spewing before my eyes after i stopped if it
wasnt fan related? thanks a lot.
shari
Reply #6June 24, 2009, 09:57:37 pm
shari
  • 13
« Reply #6 on: June 24, 2009, 09:57:37 pm »
please? :'(
shari
Reply #7June 24, 2009, 11:05:20 pm
« Reply #7 on: June 24, 2009, 11:05:20 pm »
Without a temp gauge it's hard to know if it's boiling over or if it's a blown HG.
I see no need to change the tank unless your's is cracked.
If you can hold your hand on the top rad hose for 10 seconds with the engine all the way hot then it's not overheating, if it burns you before you can take your hand off it is too hot.
it near one
I guess you probly get burned just touching the bumper too though ::)jk
Reply #8June 24, 2009, 11:43:23 pm
shari
  • 13
« Reply #8 on: June 24, 2009, 11:43:23 pm »
i guess i didnt explain that the expansion tank actually
busted a seam. and yeah the hose gets hot. doesnt burn my hand i am actually
 getting a little
more worried now after reading more stuff
about the headgasket. like would the coolant
really bust a seem like that just cause the fan
didnt come on? and there is blowby and once
on this trip the can wouldnt s/ectrical but also running on oil? i so badly dont
want it to be the headgasket cause i got 1300
miles to go and am in the middle of no where with one parts
store and no diesel mechanic. so...thanks for
your replies.
shari
Reply #9June 25, 2009, 06:15:15 am
JerryGTD
  • 89
« Reply #9 on: June 25, 2009, 06:15:15 am »
When I drove a car through Arizona-Nevada, the car overheated from the thermostat getting stuck shut. The engine got so hot that coolant spewed from the radiator cap due to the extreme pressure. I would think that your radiator cap should have released the pressure before the expansion tank burst. A stuck thermostat could cause an overpressure situation in the cooling system.
Try to flush the radiator with water at least to make sure its not clogged and use at least a 50% water 50% antifreeze mix. Don't use staight antifreeze. Maybe a new radiator cap would help. Goodluck.
1991 Jetta GL ECOdiesel
Reply #10June 25, 2009, 08:00:59 am
« Reply #10 on: June 25, 2009, 08:00:59 am »
a few bubbles in the expansion tank isn't serious.  my old car did that and was fine.  its from the small line going to the tank, it pours right in and creates a couple of bubbles.  if its building pressure very quickly from a cold start, then its a blown head gasket.  looks like you also need a new expansion tank cap as the one you had before wasn't releasing the pressure early enough.  this is to prevent damage to hoses and other parts like the heater core :o and you want to protect that heater core  ;D.  i believe there was even some kind of recall, or new part because of all the old ones failing.  something about a blue expansion tank cap???
if your radiator is getting hot, then i doubt its a stuck t-stat, although they sometimes can flow a little coolant, but not enough.  to limp it home i would suggest looking for a coolant temp gauge to tee in somewhere, as it will be your first line of defense.  you can use the heater to help reduce the temp if needed.  but because your car only overheated after coming to a stop, i feel that your t-stat is opening properly and the rad is doing its job.
so if you can't install a coolant temp gauge, then make it a habit to make sure the rad fan is coming on if you stop, or if not turn on the heater blower to max on heat.  i had to do this once on a hot day, maybe not as hot as you though... but i survived  :D  i also used a product called tow cool.  it says its compatible with regular coolant so i poured it in.  immediately i saw stabilization of my temps and they wouldn't rise as much if i was going uphill.
hope you have a safe trip home!
edit: you probably already know this, but make sure to keep lots of water in the car :)  if you use tap water or anything other than distilled/reverse osmosis, then be sure to use a rad flush in the future.
« Last Edit: June 25, 2009, 11:52:33 am by jtanguay »
Reply #11June 25, 2009, 12:06:29 pm
topless96
  • 58
« Reply #11 on: June 25, 2009, 12:06:29 pm »
Worst case is you put in some block sealer if it is a blown gasket with only a few bubbles. I would then hot wire the fan and let it run all the time. I do that in hot rods all the time. Came home from Florida and then changed the gasket and did a top end rebuild. Good luck!
Reply #12June 25, 2009, 01:53:16 pm
« Reply #12 on: June 25, 2009, 01:53:16 pm »
if you hotwire the fan to run on high speed mode, beware that the fan motor WILL fail.  the high speed mode is only meant to be ran for maybe 1-2 minutes or so max.
Reply #13June 25, 2009, 05:10:47 pm
Rabbit TD
  • 840
« Reply #13 on: June 25, 2009, 05:10:47 pm »
I think at least a simple toggle switch spliced in the car so you could at least turn it on and off and you really should get an aftermarket temp gauge to see where the temp really is.  As far as the fan running constant they are on when the AC is on anyway but I wouldn't want it wired constant.  As far as the tank busting, that had to be caused by the relief valve in the cap not releasing which they are known to do from gunk getting up inside the rubber gasket where the little valve is no matter what caused it to overheat in the first place.  I definately wouldn't reuse that cap the way it is because you will probably end up with the same problem.  If you can't get a cap then just put it on loosley enough to just stay on.  There are a lot of aditives today to help keep the engine temps down a little like was said in a previous post and I would use one, which ever they have at your parts store that they recomend, every little bit helps in this situation.  If you just have a few little bubbles that in itself should be ok.  You seem to have multiple problems but you have to have a new tank and cap, at least a cheap temp. gauge and a toggle switch to turn the fan on when it starts climbing too high, you should only need it if you are idling or on a long pull. T ;)he heater idea is also very good and it helps a little bit.  Please check back with us to let us know how you are making out.  Good luck and I hope you can keep going, make sure you have enough water like a previous post also said and plenty for yourself too if needed.  And last of all don't use The A/C if you have one or put any more load on the engine than you have to till you know how for sure how it's going to hold up.  Put your parts on and drive around where you are for a while in case you need something else you will beclose to the store.  You should know pretty quick if it's gonna  heat up or not.  You never said what kind of car it was but it sounds like the motor is about gone and I wouldn't spend a fortune on it getting a emergency rebuild or something like that, it would be too expensive and probably not hold up long anyway.
« Last Edit: June 25, 2009, 05:40:40 pm by Rabbit TD »
Reply #14June 25, 2009, 06:06:30 pm
rallydiesel
  • 1880
« Reply #14 on: June 25, 2009, 06:06:30 pm »
Do you have a/c and does it work? A/C system problems can affect the fan operation.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
