Author Topic: What is the idle speed on a 91' 1.6 TD?  (Read 3324 times)
June 22, 2009, 08:16:59 pm
91jettaidi
« on: June 22, 2009, 08:16:59 pm »
hello i have a 91' jetta with a 1.6 turbo but mine idles at 950-1000 some time what is it support to be at i know its lower then normal but is it fine for it to idle this low or should i turn it up thanks
Reply #1June 22, 2009, 10:51:04 pm
  • 3468
    • McScrubbins Body Wash
Re: What is the idle speed on a 91' 1.6 TD?
« Reply #1 on: June 22, 2009, 10:51:04 pm »
900 is not low for a diesel to idle at, at all, in my opinion.
The new TDI's idle at 900.
If it idles (and runs) properly at 950 i wouldn't change anything.
Most cars idle at 900 or 1,000 rpm except for the newer cars that will idle at 1,500-2,000 for a minute or so on a "cold" start [like parents' subaru].
(Edit:gas cars)
To the best of MY knowledge anyways.
« Last Edit: June 23, 2009, 12:07:32 pm by Smokey Eddy »
Reply #2June 23, 2009, 03:26:50 am
airhead
« Reply #2 on: June 23, 2009, 03:26:50 am »
If anything I'd have thought that was quite high. I'd have thought 800 would be more normal.
Reply #3June 23, 2009, 04:41:43 am
« Reply #3 on: June 23, 2009, 04:41:43 am »
Mine idles around 950. It's probably the smoothest there for my engine
Reply #4June 23, 2009, 05:52:23 am
ObscuredByClouds
  • 98
« Reply #4 on: June 23, 2009, 05:52:23 am »
I can't get mine to idle below around 1100 lol
Reply #5June 23, 2009, 12:08:31 pm
  • 3468
« Reply #5 on: June 23, 2009, 12:08:31 pm »
Advance the timing? turn out the fuel screw if the idle is all the way out...? You should be able to kill the engine by tampering with the pump getting the idle lower.
