Author Topic: Radiator Temp switch: are both outputs ever on at the same time?  (Read 3769 times)
June 21, 2009, 07:04:05 pm
flapjack
  • 283
My fan control is not working, so I've wired the radiator fan to a single relay.  The relay is triggered by the temp switch in the radiator.
It only activates the high fan speed.
 For now, only one of the two output wires on the temp switch go to the relay.
I want to connect both outputs to trigger the same relay. This way , either way, the fan goes off.
I am assuming they never both have power.
Is this correct?
signature
