Author Topic: 1.8L 83 GTI no electrical power  (Read 6382 times)
June 20, 2009, 06:36:48 pm
« on: June 20, 2009, 06:36:48 pm »
This is an 83 GAS 1.8L GTI...
I can't get it to do anything but light up the dash. No fuel pump, no cranking, won't jump with a screw driver. I ran it all day thursday no problems parked and went to get in friday morning and nothing. If I get in and turn the key on the dome light will go out. Sometimes if I hold the brake it will go off as well, sometimes the dash will do the same thing. I have checked the grounds, battery, fuses, and wiggled some fusable links. I am going to replace the fuseable links tomorrow when I get some butt connectors, but other than what I have done I don't know what to do.
Please let me know what to do to get it to go I am worthless almost with the gassers.
Reply #1June 20, 2009, 07:22:30 pm
rabbid79
  • 684
Re: 1.8L 83 GTI no electrical power
« Reply #1 on: June 20, 2009, 07:22:30 pm »
My brother has a Neon.  It was running perfectly until he took a curvy off-ramp from the freeway.  For on apparent reason, it died right in the middle of the curve, and couldn't be started.  The instruments in the dash worked, and the interior light would come on, but that was it.  We tried everything to get it running again.  Tested the battery voltage, wiggled the battery wires, etc.  Finally decided to bypass the factory wire by connecting one of the leads of the jumper cables between his positive battery post, and the positive lug on his fuse fox.  Fired right up.  Up inside the wire it was corroded, but looked fine from the outsite.  I would suggest you do something similar.  Connect the negative wire on some jumper cables between your negative battery post and a good clean ground on your engine.  Then connect the positive wire of the jumper cables between the positive post of your battery and the post on the starter motor, or wherever that heavy wire from the battery goes.  Give it a try.
'15 WRX
Reply #2June 21, 2009, 08:01:17 am
« Reply #2 on: June 21, 2009, 08:01:17 am »
very evident of the cutbacks large companies use to try and save a bit of cash.  the late mk3 vw's (not all) had this problem too.  maybe more models... who knows?  my starter terminal corroded off so the wire didn't have contact. gave the same symptoms...
Reply #3June 21, 2009, 09:26:27 am
DCC
  • 184
« Reply #3 on: June 21, 2009, 09:26:27 am »
I'd check the ignition switch..  :-\
Reply #4June 21, 2009, 12:27:21 pm
« Reply #4 on: June 21, 2009, 12:27:21 pm »
I dont have a switch to replace it with or I would. Is there any way to test them easily?
Also, where does the main power hook to the fuse block? Is it easy to get to or is the job an easy one?
I still don't have it going.
« Last Edit: June 21, 2009, 12:29:38 pm by theman53 »
Reply #5June 21, 2009, 07:38:24 pm
« Reply #5 on: June 21, 2009, 07:38:24 pm »
I got it.
Soldiered the fuseable links with non fuseable link stuff. Then I think I shorted the battery and added a new one and she runs.
Reply #6June 22, 2009, 05:11:42 am
« Reply #6 on: June 22, 2009, 05:11:42 am »
Had it going last night, now I have no spark and no fuel pump. It cranks just fine now though. I am thinking pickup coil any other suggestions?
Reply #7June 22, 2009, 06:27:23 am
DCC
  • 184
« Reply #7 on: June 22, 2009, 06:27:23 am »
You're almost there.  ;)
Check the cables yet again. The gasser fuel pump is activated via a relay in the fusebox. It has its own fuse, so maybe it's toast.
Are you sure you have no spark? Did you check against the block? Are you getting steady voltage at the coil after contact?
Reply #8June 22, 2009, 11:15:19 am
« Reply #8 on: June 22, 2009, 11:15:19 am »
Reworked one of the fuseable links AGAIN and it is going...nothing like a day of troubleshooting for a 3 minute fix. :-X >:( >:( :-X :'( :'( :'( :'( :'( :'(
