Author Topic: Quarter Mile: 18.267 @ 75.02  (Read 2750 times)
June 20, 2009, 06:57:09 am
ObscuredByClouds
  • 98
« on: June 20, 2009, 06:57:09 am »
ET: 18.267
Trap: 75.02
60 foot: 2.687
RT: 0.401
1/8: 11.7 @ 60 (lol 0-60 time)
By 3rd gear boost held at 26psi and I just didn't really accelerate. Aside from over boost, I think an intercooler will help with the top end issues.
« Last Edit: November 25, 2011, 01:58:39 pm by ObscuredByClouds »
Reply #1June 20, 2009, 08:28:55 am
MJF
  • 581
Re: 1/4'in LOL
« Reply #1 on: June 20, 2009, 08:28:55 am »
Lower your boost, turn more fuel and add intercooler and youŽll be in 15Žs ;D You are already faster than stock TDI...
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2June 21, 2009, 01:49:52 am
  • 3468
    • McScrubbins Body Wash
Re: 1/4'in LOL
« Reply #2 on: June 21, 2009, 01:49:52 am »
there is such a thing as too much boost?
Reply #3June 21, 2009, 04:26:21 am
MJF
  • 581
Re: 1/4'in LOL
« Reply #3 on: June 21, 2009, 04:26:21 am »
Yes. Use as low boost as possible.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #4June 21, 2009, 12:55:42 pm
Re: 1/4'in LOL
« Reply #4 on: June 21, 2009, 12:55:42 pm »
As LOW boost as possible? please explain as to why people always want to go for the biggest boost their engine can handle then? I'm right confused now lol
Reply #5June 21, 2009, 01:28:51 pm
Re: 1/4'in LOL
« Reply #5 on: June 21, 2009, 01:28:51 pm »
OHH so in a way its almost like your cramming in too much air type thing? not getting a good even mix  of fuel and air for the engine?
Reply #6June 21, 2009, 02:01:00 pm
Re: 1/4'in LOL
« Reply #6 on: June 21, 2009, 02:01:00 pm »
the turbine efficiency range is 17 psi or so for a K14, and about 20 psi for a K24.  once you go above that, the exhaust back pressure becomes higher than the intake pressure.  so in theory the engine has to work harder to sustain the boost pressure.
Reply #7June 21, 2009, 03:57:40 pm
OM617
Re: 1/4'in LOL
« Reply #7 on: June 21, 2009, 03:57:40 pm »
More boost than needed to burn the fuel injected restricts the exhaust and excessively heats the air. At 26psi your charge air is 380*f, at 15psi its 220*f.
Reply #8June 21, 2009, 08:35:53 pm
Re: 1/4'in LOL
« Reply #8 on: June 21, 2009, 08:35:53 pm »
i did low 16s with my 1.6.  closed wastegate on a k24 25-30psi, turned up fueling, cone filter, and 2 1/4 inch exhaust off the stock cast down pipe, in a mk1 jetta coupe with no ac or sun roof.
