Author Topic: options for clutch/flywheel upgrades?  (Read 2224 times)
June 19, 2009, 08:05:16 am
sour diesel
  • 19
« on: June 19, 2009, 08:05:16 am »
Hey all new to these boards & must say brilliant source for everything diesel, love yall. Anyway im looking for upgraded clutch & flywheel options for my fn code 1983 td rabbit. please any tips will be appreciated. cheers
Reply #1June 19, 2009, 10:12:15 am
gigaz2
  • 626
Re: options for clutch/flywheel upgrades?
« Reply #1 on: June 19, 2009, 10:12:15 am »
on a 085 type gearbox? stock TD parts handle pretty much all the torque you can throw at them with a 1.6 engine
mega upgrade:
020 type gearbox, G60 transmissions, G60 flywheel and vr6 clutch
pretty bombproof until things get really interesting on the engine side (250hp++)
Reply #2June 19, 2009, 06:24:26 pm
« Reply #2 on: June 19, 2009, 06:24:26 pm »
Is the VR6 clutch/flywheel a direct swap in for the 020 behind a 1.6?  (timing marks are different obviously)
Reply #3June 20, 2009, 08:04:06 am
« Reply #3 on: June 20, 2009, 08:04:06 am »
There are other options, but something like this could be a real on off switch. I went with a 1.9L pressure plate, but this is available for a 1.6L as well.
Reply #4June 20, 2009, 05:21:31 pm
sour diesel
  • 19
« Reply #4 on: June 20, 2009, 05:21:31 pm »
I think what I really want to know is if my fn code 5sp trans will mate with 210mm small spline clutch & flywheel set up yhat bfi sells?
Reply #5June 20, 2009, 06:25:08 pm
« Reply #5 on: June 20, 2009, 06:25:08 pm »
I believe if it is 26 small spline then it should.
