TDI Engine -General Info
can you tune a 2.5 TDI
Topic: can you tune a 2.5 TDI (Read 4002 times)
June 18, 2009, 04:55:29 pm
oldskool rich
June 18, 2009, 04:55:29 pm »
just about to buy an audi a6 tdi, just want to know if anything can be done for more powers?
can you get bigger pump pistons?
will the LDA fit off a disco pump?
can you use a bleed valve for more boost with the stock set up?
f6squared I.D.S.T
June 18, 2009, 05:09:51 pm
gigaz2
Re: can you tune a 2.5 TDI
June 18, 2009, 05:09:51 pm »
2.5 I5 TDI or 2.5 V6 TDI ?
both use E pumps, LDA doesn't apply
the I5 already has the biggest pump bosch made for 5 cylinder apllication
bleed might work, check light and limp mode if you overdo it
June 18, 2009, 08:58:14 pm
blackdogvan
June 18, 2009, 08:58:14 pm »
2.5 V6 m-tdi with Cummins 12mm VE pump. DOitDOitDOitDOitDOit.
1991 Vanagon 1.9 mTDI
June 19, 2009, 05:09:50 am
June 19, 2009, 05:09:50 am »
In my mind, i prefer keeping electronic pump.
June 19, 2009, 07:38:58 am
blackdogvan
June 19, 2009, 07:38:58 am »
Quote from: ptit_lolo on June 19, 2009, 05:09:50 am
Ya but it's Rich!
June 19, 2009, 06:28:10 pm
oldskool rich
June 19, 2009, 06:28:10 pm »
na its 5 cylinder, the V6s are gash aparently, i realy hate electrics, just wonderd if it was possible to go M-TDI can you not get 14mm pump pistons?
ive been looking into getting one for my 4 cylinder, do you think thats over kill? took my disco IP apart and sold the pump piston so im forced to buy sumthin better
f6squared I.D.S.T
June 20, 2009, 04:56:08 am
MJF
June 20, 2009, 04:56:08 am »
Stock 5cyl tdi pump needs no modifiacations to ~300hp.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
June 20, 2009, 05:11:05 am
June 20, 2009, 05:11:05 am »
Quote from: MJF on June 20, 2009, 04:56:08 am
Exactly. And 5 cyl TDI uses an 11mm head.
