Author Topic: glowplug control unit  (Read 4045 times)
June 18, 2009, 06:48:34 am
haybayian
  • 155
« on: June 18, 2009, 06:48:34 am »
I was given an object called "gluhzeitsteuergerat" 0 281 003 007 made by Bosch when I bought a Detroit diesel engine years ago. Now my understanding is that I am looking at a glowplug timer, right? Is that something I could use to time the glowplugs on my AAZ?
Thanks
Haybayian
Keep it simple if you can.
Reply #1June 19, 2009, 02:25:16 am
Golf/Jetta
  • 102
Re: glowplug control unit
« Reply #1 on: June 19, 2009, 02:25:16 am »
i don't think you can set these, but heres a fix
big solenoid (that can handle 75 amps), a botton to activate. and a finger with precision timing. easy, simple..
i plan on doing this as a addon with my current glowplug circuit, with a switch auto, off, on
or you can replace it. theres two type of glowplug circuits, slow (6 sec.) fast (3 Sec). don't forget pre (before you sit) and post (after a driving block)..
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #2June 19, 2009, 05:43:48 am
haybayian
  • 155
« Reply #2 on: June 19, 2009, 05:43:48 am »
 Thanks for your tip, I will look into this.
Haybayian :)
