Author Topic: problem with 16 td diesel pump  (Read 2356 times)
June 17, 2009, 11:03:42 am
tzrypvs
  • 5
« on: June 17, 2009, 11:03:42 am »
I want to modify as i look in this forum the diesel pump to go faster but i don't have the pump that i see in your photo. i have this one (http://www.vanagon.eu/pics/t3pumpejx.jpg). can i do the modify with this pump? can something explein me how i can do with this?
Reply #1June 17, 2009, 11:44:15 am
rallydiesel
  • 1880
Re: problem with 16 td diesel pump
« Reply #1 on: June 17, 2009, 11:44:15 am »
The problem is that is not a turbo pump. You can still do the max fuel screw adjustment. Check the "Making your n/a 1.6 faster" section (is there one?). You could probably add a 1.9 cam plate but your gonna have smoke issues as you add more fuel.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2June 17, 2009, 11:46:47 am
rallydiesel
  • 1880
« Reply #2 on: June 17, 2009, 11:46:47 am »
Here's the section you want to read:
http://www.vwdiesel.net/forum/index.php?topic=4391.0
Reply #3June 17, 2009, 01:12:33 pm
tzrypvs
  • 5
« Reply #3 on: June 17, 2009, 01:12:33 pm »
IS not a turbo pump? But my motor is 1600 td with k24.  Now i think that the last owner have a not turbo motor and he put on the turbo. Now what can i do?
Reply #4June 17, 2009, 01:55:11 pm
tzrypvs
  • 5
« Reply #4 on: June 17, 2009, 01:55:11 pm »
One error. My pump is like this one but i have the LDA. so i think that is a turbo pump. The problem is that i sdifferent like the pump that i can see on the post "more power for your 16 td" so i can't modify this.
Thanks.
Reply #5June 17, 2009, 01:57:08 pm
Reply #6June 19, 2009, 02:48:21 am
tzrypvs
  • 5
« Reply #6 on: June 19, 2009, 02:48:21 am »
Yes but there aren't modification for my pump like other pump. Can't i make nothing to have more power?
Reply #7June 19, 2009, 12:40:29 pm
« Reply #7 on: June 19, 2009, 12:40:29 pm »
yes there is,
As mentioned above read this thread http://www.vwdiesel.net/forum/index.php?topic=5843.0
you can still do the GOV mod and turn the fuel screw.
EVERY VE Pump has this ability so unless your not running a VE pump you can do it.
This thread is still applicable as well.  http://www.vwdiesel.net/forum/index.php?topic=4391.0
