Author Topic: Fuel additives: Lucas upper cylinder lube  (Read 4969 times)
September 09, 2005, 01:03:28 pm
Patrick
  • 1034
« on: September 09, 2005, 01:03:28 pm »
As a rule, I figure the guys building the fuel we buy know what they're doing, and have never used additives unless I knew I had a problem. Drove a big truck for a lot of years, only had a gel problem once, ice due to condensation a couple of times. That said, I thought I'd try some of the additive mentioned above, just for the heck of it. Not supposed to have any alcohol type substances, so shouldn't do any damage, right?
Been running about 45l of fuel in 800 km.
First tank with additive, 780km on 40l.
Have to run a few more tanks to check, but it looks good so far!
Car is a 4door mark2 Jetta with a 1.9idi and a 5 speed with the big overdrive. haven't checked, but suspect it's showing a little shy on km due to tire size (195/60R15). If that's the case, mileage is actually better than it shows here.
Anybody else have similar results?
Reply #1September 09, 2005, 03:15:10 pm
zyewdall
  • 393
« Reply #1 on: September 09, 2005, 03:15:10 pm »
I can't speak for this particular additive, but if it does increase lubricity of the fuel, I can see that it might help, especially with the new low sulfer fuel.  A B20 blend usually gets slightly better mileage than regular diesel, despite having lower btu/gallon content.  Although whether this is due to high lubricity, or higher cetane rating, is a question.
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #2September 09, 2005, 09:29:12 pm
« Reply #2 on: September 09, 2005, 09:29:12 pm »
cetane boosters are always good.  More power means higher MPG :) and lubricating your (expensive to repair) pump is a BONUS :)
Reply #3September 10, 2005, 03:00:09 am
rubberducky
  • 38
not to take this off into a tangent, but...
« Reply #3 on: September 10, 2005, 03:00:09 am »
any one hear of adding acetone to fuel?  came across this the other day.  what do you think:
http://www.lubedev.com/smartgas/faq.htm
says does no harm to engine components; i have my doubts...  but sure sounds attractive though.
Cheers.
Reply #4September 10, 2005, 09:39:30 am
Mark(The Miser)UK
  • 1557
« Reply #4 on: September 10, 2005, 09:39:30 am »
Quote from: "zyewdall"
Just run 5% Cannola for that extra lubricity...
Mark-The-Miser-UK
Reply #5September 10, 2005, 09:58:03 am
Mark(The Miser)UK
  • 1557
Re: not to take this off into a tangent, but...
« Reply #5 on: September 10, 2005, 09:58:03 am »
Quote from: "rubberducky"
Cheers.
This is part of that link:
What kind of mileage increase will acetone give my car?     Normally from 15% to 35% depending on your driving habits and how many of our mileage suggestions you have taken. We know an aeronautical engineer in San Jose whose test car went from a baseline of 19.3 MPG to 27. He certified this with his ScanGauge. That is a genuine boost of 27%.
Miser says:
Acetone is a powerful solvent that disolves tar and petroleum based products. It's noxious too. Unless I'm a monkey this is as far from a lubricant as you can get. His gasser fuel economy improvement was probably because the acetone removed the oil from a gummed up sparkplug so it now runs on 4 cylinders rather than 3! This would not be going in my fuel tank... period... ( even though I have 4 TD pumps to play with!!!
Cheers
Mark-The-Miser-UK
Reply #6September 10, 2005, 11:55:55 am
QuickTD
  • 1156
« Reply #6 on: September 10, 2005, 11:55:55 am »
The theory is that acetone acts as a surfactant and reduces the surface tension of the fuel, resulting in better atomizationand therefore a more complete burn. 15 to 35% improvement seems a tad optimistic, maybe in an ancient engine with 3 of the 4 injectors squirting rather than spraying the acetone might dissolve the gunk and open them up, yielding good results. Very few vehicles in a respectable state of tune will lose 15-35% of thier fuel out the tailpipe.
Reply #7September 10, 2005, 03:14:31 pm
rubberducky
  • 38
« Reply #7 on: September 10, 2005, 03:14:31 pm »
thanks for clearing that up for me.  sounded rather sketchy...
Cheers.
Reply #8September 10, 2005, 05:00:28 pm
Mark(The Miser)UK
  • 1557
« Reply #8 on: September 10, 2005, 05:00:28 pm »
Quote from: "Mark(The Miser)UK"
Miser says:
Cheers
Also I never trust somone who is trying to sell me something when his maths doesn't add up...
(27-19.3)/ 19.3 is a 39.8% improvement :roll:
I wouldnt want to be driving to work behind this Aeronautical Engineer :shock:
Wots a Scan Gauge? Sounds like it needs recallibrating
Sorry rant off  :twisted:
Mark-The-Miser-UK
Reply #9September 11, 2005, 08:19:30 pm
« Reply #9 on: September 11, 2005, 08:19:30 pm »
well isn't the alcohol they put into gasoline worse than acetone?
Reply #10September 12, 2005, 12:39:58 am
Mark(The Miser)UK
  • 1557
« Reply #10 on: September 12, 2005, 12:39:58 am »
Quote from: "jtanguay"
Hi
Who you talking about?
If the oil barons are doing that over here then it's news to me :shock:
Different issues with a gasser; I'm only thinking of the Bosche pump and injector parts that rely on lube.
Mind you over in the Americas you seem to have a great issue with bad fuel,If I unscrew the filtre drain once every 2 years I probably will not find a single trace of water!
Mark-The-Miser-UK
Reply #11September 12, 2005, 03:35:09 am
« Reply #11 on: September 12, 2005, 03:35:09 am »
The oil companies don't put ethanol in diesel, just gas.   Ethanol is supposedly as bad as acetone as an additive.  Just gives more reason to drive a diesel :D
Reply #12September 12, 2005, 03:55:39 am
rubberducky
  • 38
ScanGauge
« Reply #12 on: September 12, 2005, 03:55:39 am »
here's the URL for the ScanGauge that was mentioned earlier:
http://scanguage.com/
seems nifty, and not all that expensive...  although i can't use it in my Jetta.  could be useful in my gasser V8.
