Non VW Group Diesel
Motorola tachometer
Topic: Motorola tachometer (Read 4845 times)
June 17, 2009, 08:18:13 am
TOW'D
Motorola tachometer
June 17, 2009, 08:18:13 am »
Howdy Gang,
A friend has a converted 40ft F/G fishing boat with a huge Skanda(spelling? built by the SAAB people)diesel.
The electronic Motorola tach just stopped working- there is a sensor threaded into the bell housing to read the rpm.
Both the tach and sensor have continuity( no open circuit), the wires are good-power and ground to tach head is also good.
So the only thing I can think of being wrong is maybe the magnet came out of the flywheel.
Now I really don't know if there is a magnet in the flywheel or if the sensor reads the flywheel teeth.
Anybody have any suggestions
thanks
hank
way too many projects not much time
June 19, 2009, 03:35:14 am
Patrick
Re: Motorola tachometer
June 19, 2009, 03:35:14 am »
Had a setup like this in a big truck I used to have. It doesn't work off the teeth, that's for sure! Never had a problem other than a bad connection . Not sure how it read, suspect a magnet.
June 21, 2009, 08:03:18 am
TOW'D
June 21, 2009, 08:03:18 am »
Thanks Patrick
I'm going to test the sensor with a magnet by shaking it back and forth to see if the needle will move.
Then spin the flywheel (by hand)and look at the teeth for a missing magnet
At least there is a lot of space in the engine room to get around.
cheers
hank
July 03, 2009, 03:20:55 pm
Zulfiqar
July 03, 2009, 03:20:55 pm »
if its built by SAAB they must be using a corbino effect wheel on the crank to trigger a hall sensor, thats how SAAB usually like it
check the resistance of the sensor itself - that may cause a dead signal
Diesel IS the future
July 08, 2009, 07:24:53 am
TOW'D
July 08, 2009, 07:24:53 am »
We tested the sensor by moving a magnet across the face and got no reading
the gauge needle does move when the key is turned on so it must be good
Having a hard time finding the parts
thanks for the reply
hank
Non VW Group Diesel
Motorola tachometer
